chtMultiRegionSimpleFoam temperature goes to below zero |
July 1, 2019, 03:26 |
shach
Rep Power: 7 |
Hi Fomers,
I am using chtMultiRegionSimpleFoam to simulate cooling of a rotating disc. The geometry is attached. In a wind tunnel a disc is rotating, temperature of the surface of the disc is higher than the air. Here is the boundary condition and the thermophysicalProperties of air and disc. For air 0/air/T Code:
dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 300; boundaryField { inLet { type fixedValue; value $internalField; } rr_slave { type cyclicAMI; } air { type fixedValue; value $internalField; } outLet { type zeroGradient; } air2disc { type compressible::turbulentTemperatureCoupledBaffleMixed; value uniform 300; Tnbr T; kappaMethod fluidThermo; } rr { type cyclicAMI; } air2disc_heat { type fixedValue; value uniform 500; } } Code:
dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 300; boundaryField { disc2air { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod solidThermo; value uniform 300; } heat2air { type fixedValue; value uniform 500; } } Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { // coefficients for air specie { molWeight 28.85; } thermodynamics { Cp 1004.4; Hf 2.5e6; } transport { mu 1.8e-5; Pr 0.705; } } Code:
thermoType { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } mixture { specie { molWeight 55; } transport { kappa 80; } thermodynamics { Hf 0; Cp 450; } equationOfState { rho 7800; } } Anyone has any suggestion? Thank! |
July 1, 2019, 04:17 |
Rep Power: 12 |
Have you checked the pressure and velocity boundary?
I use chtMultiRegionSimpleFoam also and have met the same problem before. After I corrected the pressure boundary, it converged normally. Another reason maybe the schemes you used. Sometimes when I used a not such appropriate scheme, the calculation diverged soon. |
July 1, 2019, 04:59 |
shach
Rep Power: 7 |
Hello Carye,
Thanks for your suggestion! Would you mind to take a look at my pressure and velocity boundary conditions? Thanks! Here is the pressure for the disc Code:
dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 0; boundaryField { disc2air { type calculated; value $internalField; } heat2air { type calculated; value $internalField; } } Code:
dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 1e5; boundaryField { inLet { type zeroGradient; } rr_slave { type cyclicAMI; } air { type zeroGradient; } outLet { type fixedValue; value $internalField; } air2disc { type zeroGradient; } rr { type cyclicAMI; } air2disc_heat { type zeroGradient; } } Code:
dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 1e5; boundaryField { inLet { type zeroGradient; } rr_slave { type cyclicAMI; } air { type fixedFluxPressure; value $internalField; } outLet { type fixedValue; value $internalField; } air2disc { type fixedFluxPressure; value $internalField; } rr { type cyclicAMI; } air2disc_heat { type fixedFluxPressure; value $internalField; } } Code:
dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform ( 0 -6.944 0 ); boundaryField { inLet { type fixedValue; value $internalField; } rr_slave { type cyclicAMI; } air { type noSlip; } outLet { type inletOutlet; inletValue uniform ( 0 0 0 ); value $internalField; } air2disc { type noSlip; } rr { type cyclicAMI; } air2disc_heat { type noSlip; } } |
July 1, 2019, 05:42 |
Rep Power: 12 |
I'm sorry that I'm not an expert.
But how about set the fixedFluxPressure in the p_rgh as zeroGradient? I remember in my calculation I also tried fixedFluxPressure but it was unstable, so I used zeroGradient and finally got the result. Another is that the p boundary is not used in the chtMultiRegionSimpleFoam because p is calculated from p_rgh. So the pressure boundary will affect the calculation is p_rgh. Hope this may help you. |
July 1, 2019, 07:12 |
shach
Rep Power: 7 |
Hi Carye,
Thanks for your suggestion. I tried with zeroGradient boundary condition for p_rgh, unfortunately it is still not working. I will try with a simpler case now and check if this is caused by cyclicAMI boundary. |
July 1, 2019, 16:11 |
Tobias Holzmann
Rep Power: 51 |
Just one hint... why do you use cyclicAMI if there is no motion?
Furthermore, if you get a few iterations, you can save them and check the results to see what field makes problems and especially at which location. Can you let us know your fvSchemes and solver settings?
Keep foaming, Tobias Holzmann |
July 1, 2019, 16:54 |
shach
Rep Power: 7 |
Hi Tobi,
The cyclicAMI is for the nonconformal mesh between the rotating region and the stator region. It is not the source of the problem since I tried without the MRF. In fact, I already solved the problem. There is something wrong with the fvSolution, the pRefCell and pRefValue was set wrong, I changed it a little bit and it works.... Thanks. |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Static temperature and Total temperature | Jong-Yoon | FLUENT | 0 | September 25, 2016 01:42 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
difference of temperature | HKH | FLUENT | 0 | January 28, 2010 02:45 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
