User defined dynamic mesh
Hi all,
Recently I am doing the dynamic mesh cases. I am trying to follow the case movingCone to setup the moving part. /opt/openfoam6/tutorials/compressible/sonicDyMFoam/movingCone ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ file: dynamicMeshDict dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libfvMotionSolvers.so"); motionSolver velocityComponentLaplacian; component x; diffusivity directional (1 200 0); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ file: pointMotionUx FoamFile { version 2.0; format ascii; class pointScalarField; object pointMotionU; } boundaryField { movingWall { type uniformFixedValue; uniformValue constant 160; } ... } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ In the file pointMotionUx, it shows the type for the movingWall is 'uniformFixedValue'. Can anyone show me how to select the type if I want to define the moving path using a function or reading the velocity profile from a file? Thanks, Chao ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ The following shows the type for the moving wall. Valid patchField types are : 22 ( calculated codedFixedValue cyclic cyclicACMI cyclicAMI cyclicRepeatAMI cyclicSlip empty fixedNormalSlip fixedValue nonuniformTransformCyclic processor processorCyclic slip symmetry symmetryPlane timeVaryingMappedFixedValue timeVaryingUniformFixedValue uniformFixedValue value wedge zeroGradient ) |
