Paraview - Calculation of Swirl Angle
Old   July 8, 2019, 11:33
Default Paraview - Calculation of Swirl Angle
foamF is on a distinguished road
Swirl angle is a useful parameter to describe the inlet performance of a pump suction. It is defined as the ratio of tangential velocity to axial velocity.
Any expert here can explain how to calculate the swirl angle for a given plane in Paraview (possibly based on the calculator filter)? Is it necessary to do the calculation based on the vorticity results, or just the velocity results are used?
Thanks a lot.
foamF is offline   Reply With Quote
Old   July 13, 2019, 05:41
Any expert here can advise?
Is it appropriate to use the surface integral of vorticity (curl) to find the average tangential velocity?
Old   November 3, 2021, 02:58
Munaf
mwmalkawi is on a distinguished road
Did you manage to find an answer to this please
mwmalkawi is offline   Reply With Quote
[General] Wall Shear Stress Calculation with Paraview ahmet ParaView 1 June 20, 2019 18:57
Resultant swirl angle OOTB Main CFD Forum 0 October 21, 2016 05:23
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 08:05
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 03:07
[OpenFOAM] Flux Calculation in ParaView dinksy ParaView 0 October 17, 2012 00:33
