Dynamic and Static Mesh
Old   July 9, 2019, 17:06
Default Dynamic and Static Mesh
MO
czb58 is on a distinguished road
Hi all,
I want to do the simulations with dynamic mesh. Please find the following figures for the problem. The movingWall only moves in x-direction. So I following movingCone case in the tutorial to setup the file 'pointMotionUx'.
The problem is that the mesh will move in the whole domain. I just want the mesh to move in the 'dynamic zone' as shown in the figure 2. The last figure shows the mesh after it moves. Can anyone tell me which motion solver I should use? or how can I separate the zone to make sure that the mesh only moves in a specific zone?
Thanks,
Chao
file: dynamicMeshDict
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
motionSolver velocityComponentLaplacian;
component x;
diffusivity directional (1 100 0);
czb58 is offline   Reply With Quote
Old   July 15, 2019, 15:46
MO
It looks like nobody wants to answer this question.
Old   July 16, 2019, 06:03
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I would not use the topoCone example as it is for cell remove/adding purposes and the set-up is a bit more difficult as you think. I would just move the wall you defined to be moved. Somehow like in this video https://www.youtube.com/watch?v=Atoz4VVuV5A.
You need to use a dynamic mesh solver and move the boundary you want. All other patches are fixed and the cells inside your mesh gets distorted based on a diffusion equation.
Good luck.
Tobi
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
[mesh manipulation] How to combine dynamic mesh and static mesh chery1986 OpenFOAM Meshing & Mesh Conversion 17 October 25, 2023 00:55
udf for valve closing a pipe using dynamic mesh chem engineer Fluent UDF and Scheme Programming 2 May 13, 2017 09:39
Dynamic mesh is not getting updated. cardio FLUENT 1 May 20, 2014 08:41
How to know mesh size after dynamic refinement tayo OpenFOAM 16 May 22, 2013 13:39
Use mesh motion to introduce angle for static simulation dancfd OpenFOAM Running, Solving & CFD 1 November 18, 2010 19:15
