problem of streamFunction in buoyantBoussinesqSimpleFoam
Old   September 28, 2011, 12:39
Default problem of streamFunction in buoyantBoussinesqSimpleFoam
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
hi Every one!
i m using openfoam 201
i have problem to plot streamFunction i solved problem for laminar nonisothermal cavity flow with buoyantBoussinesqSimpleFoam.
when i run streamfunction then it gave me error but when i run another solver like icoFoam,SimpleFoam then streamfunction works but in buoyantBoussinesqSimpleFoam it cant work so what can i do?
plz tel me how can i plot streamFunction?
tel me how to plot streamFunction using buoyantBoussinesqSimpleFoam.
i found error like,
Create mesh, no clear-out for time = 0
Time: 0
--> FOAM Warning :
From function streamFunction
in file streamFunction.C at line 456
Flux field does not exist. Stream function not calculated
Time: 100
Reading field phi
Zero face: patch: 0 face: 0
#0 Foam::error: printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/streamFunction"
#4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
abcz@abcz-desktop:~/Desktop/sample$
so anybody can solve my problem?
jignesh_thaker2007 is offline   Reply With Quote
Old   September 28, 2011, 16:16
Nima Samkhaniani
nimasam is on a distinguished road
is there phi in your time folder?
you can use paraview or other post processing program to plot streams too
nimasam is offline   Reply With Quote
Old   September 29, 2011, 02:41
Default hi nima
Jignesh
yes in time folder phi is available.
so how can i write my data of stream function? because in other solver streamFunction command works but in this solver it cant work
i need the value of stream function so how can i run this command?
Old   September 29, 2011, 04:49
Nima Samkhaniani
is ur geometry 2D or 3D? streamFunction only works for 2D geometry
Old   September 29, 2011, 12:25
Jignesh
ya in 2d. i short-out that problem but
when i give the command of streamFunction then it took the value of phi but it give me msg like
Reading field phi
Exhausted a seed. Looking for new seed (this is correct for multiply connected domains).
& when i plot this value in tecplot it gave me roungh answer
actually my value of vorticity is right but streamfunction value is incorrect so now tel me what can i do?
Old   July 9, 2019, 05:58
Alya2212 is on a distinguished road
Did you managed to solve the problem?
Alya2212 is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
