How to read dictionary variables from another dictionary
Old   August 1, 2019, 09:18
Default How to read dictionary variables from another dictionary
Evren Linda's Avatar
Evren Linda
Evren Linda is on a distinguished road
In OpenFOAM, we can create variables in dictionary files. For example, in 0/U (The U file in 0 folder)I can define a variable xvelocity like this:
// I define the variable xvelocity and assign it the value 15
xvelocity      15;
// In the same dictionary I can access the variable using $ sign.
value      ($xvelocity 0 0);
My question: Is it possible to access variables (in this example: xvelocity) from other files, say: 0/p or any other dictionary file in the OpenFOAM case?
Evren Linda is offline   Reply With Quote
Old   August 1, 2019, 12:01
Adhiraj
adhiraj is on a distinguished road
I don't know for sure, but it is possible that variables defined in a dictionary such as xvelocity in your example, are local to the dictionary they are defined in.
One problem with having such variables available to other files would be this: can you guarantee that the dictionary containing the variable is read before the one that needs to use it?
adhiraj is offline   Reply With Quote
Old   August 1, 2019, 17:05
Evren Linda
Thank you for your reply
Currently I am looking for some tricks but I am not sure if that will work. I want to use #codeStream or codedFixedValue to access inputs from other dictionaries. I will post any relevant progressing steps here.
Old   August 1, 2019, 17:47
Utkan Caliskan
dscian is on a distinguished road
It is possible. You need to include the file. In your 0/U file, add the following
#include   "path-to-file/file"
You can also check $FOAM_TUTORIALS/incompressible/simpleFoam/turbineSitting tutorial for the implementation.
dscian is offline   Reply With Quote
Old   August 1, 2019, 18:00
Evren Linda
That will include the entire file which is not safe (which will pollute the current dictionary and may overwrite some variables ...etc). I am looking for a way to read only some specific entries.
Old   August 2, 2019, 08:28
Mathias Poulsen
SvenBent is on a distinguished road
Hi.
You could just define all the variables you need in a separate file and include that into the files where you need them.
Say that you make a file:
0/variables/myvars
where you define the variables:
xVelocity 15;
banana 4;
And then in 0/U and 0/p you include it as dscian suggested.
That way you do not risk the chance of overwriting dictionaries.
Best regards
Mathias
SvenBent is offline   Reply With Quote
Old   August 2, 2019, 08:35
Evren Linda
Originally Posted by SvenBent View Post
Hi.
0/variables/myvars
xVelocity 15;
banana 4;
Best regards
Mathias
Thank you for your reply. Actually, I am aware of this. But I don't really like to create a separate file just to share variables between dictionaries, in my case, this approach is very error-prone. So I am looking for a way to read variables from other dictionaries directly without using intermediate files.
Old   August 2, 2019, 19:05
Evren Linda
I just figured it out, using #codeStream and using this function
#include <iostream>
#include <stdexcept>
#include <stdio.h>
#include <string>
std::string exec(const char* cmd) {
    char buffer[128];
    std::string result = "";
    FILE* pipe = popen(cmd, "r");
    if (!pipe) throw std::runtime_error("popen() failed!");
    try {
        while (fgets(buffer, sizeof buffer, pipe) != NULL) {
            result += buffer;
    } catch (...) {
        pclose(pipe);
        throw;
    pclose(pipe);
    return result;
This function will execute a shell command and return its value.
Now, we can combine this with the famous utilty foamDictionary to read dictionary entries and modifying them;
Here is an example of usage:
// This will change the value of the entry myVar in 0/p file
word mycmd = exec("foamDictionary 0/p -entry myVar -set 85580");
// and this will read its value and return it
word myvar = exec("foamDictionary 0/p -entry myVar -value");
Trackbacks are On
read IOObject::NO_WRITE/AUTO_WRITE from dictionary jameswilson620 Main CFD Forum 0 July 17, 2015 11:52
Parallel Error in ANSYS FLUENT 12 zeusxx FLUENT 25 July 17, 2015 04:40
How to read a list from a dictionary? ivan_cozza OpenFOAM Programming & Development 6 November 7, 2014 08:31
Overwriting dictionary from BC Phicau OpenFOAM Programming & Development 1 January 25, 2013 04:24
New Boundary Condition: Reading Dictionary Problem Koga OpenFOAM Programming & Development 0 November 26, 2012 05:01
