Translating 'U' file from OpenFOAM 3 to OpenFOAM 5
In an older openfoam 3 case file, the 'U' file was written as such:
dimensions [0 1 -1 0 0 0 0]; What changes do I need to make in 'U' to make the case compatible with openfoam5? Thanks. |
No one to answer this query? I urgently need the solution, I would be very grateful for any help in this matter.
As you can see in the case: $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/propeller, there are some scripts to run the case, mainly:
Allrun and Allrun.pre. The script Allrun calls Allrun.pre before running the solver. So you have first to run Allrun.pre script before running the solver: Code:
./Allrun.pre |
