Boundary conditions for k and epsilon on a periodic channel flow
Hi everyone,
I'm simulating a flow through a channel. I impose a mean velocity which traduces in a pressure gradient calculated by openFoam. Here are boundary and initial conditions for Pressure: Code:
boundaryField Code:
boundaryField Boundary conditions for k: Code:
boundaryField Code:
boundaryField Has anyone worked with similar cases? any suggestion will be wellcome Thanks, Maveryck. Note: y+ at the walls have values around 5-8. |
Your boundary conditions are fine for those y+ values.
I expect this is because of the turbulence model you are using - k-epsilon is unsuitable for these flows unless you use highRe wall functions (i.e y+ levels are in the log-region). Try v2-f if you want to use an epsilon-based model, or use an omega-based model if you don't want to use the four-equation one. |
When you have problems finding suitable values you can try out the cfd-online tools.
https://www.cfd-online.com/Tools/turbulence.php |
