output the species mass fractions
Old   August 26, 2019, 05:55
Default output the species mass fractions
openfoammaofnepo is on a distinguished road
Hi All,
For the combustion problems modelled with detailed chemical mechanism, we will typically tens of species or more. In openfoam, all the species mass fraction solved by the equations will be output in the results folders. Is it possible to selectively output some species? Because we are always interested in some of the species and if we output all, they can use lots of data space. Thanks a lot.
openfoammaofnepo is offline   Reply With Quote
Old   August 26, 2019, 06:05
Philipp Conen
pconen is on a distinguished road
Did you start your case already?
I think in paraView you can choose what species you want to see. This option is equal to choose velocity or pressure. For me this works. But I work on mixing problems and not combustion problem.
I hope I could help you.
Greetings
Philipp Conen
pconen is offline   Reply With Quote
Species Transport: How to determine the mass flux from concentration gradients? Zaphod'sSecondHead FLUENT 2 January 9, 2016 09:16
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 08:26
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
fluent definitions for mass fractions perdita FLUENT 0 December 6, 2010 06:00
UDF and PDF species mass fractions Ale FLUENT 0 July 18, 2003 10:04
