PressureJump Errors simpleFoam for Ducted Fan
Hello foamers !
All pictures and files can be found at : https://www.dropbox.com/sh/qcgk5ajlp...q1t7sNF-a?dl=0 I'm trying to simulate the behaviour of a ducted fan(picture 1) by representing my propeller with a pressure Jump on a baffle in a 3D model of my duct. But I faced some complications (especially singularities in the pressure field on the rotor disk as shown in picture 2, I have similar singularities in the U field) and would be delighted if you would share experience or intuition on this case. https://www.dropbox.com/s/hlx8lfbm5r...0Mesh.JPG?dl=0 picture 1 at (https://www.dropbox.com/s/hlx8lfbm5r...0Mesh.JPG?dl=0) https://www.dropbox.com/s/g4jp3qe84l...rrors.JPG?dl=0 picture 2 at (https://www.dropbox.com/s/g4jp3qe84l...rrors.JPG?dl=0) Introduction I'm running on OF18.12, a steady state, incompressible, turbulent (using K-omega model) with simple Foam on a cartesianMesh generated by cfMesh (I also tried to apply pMesh and to use snappyHexMesh, more details below). I'm running it on various amount of processors (usually between 70 and 96) using scotch decomposition. Meshing What I tried to do both with CfMesh and Snappy Hex Mesh was to mesh all my domain and duct and in that mesh create a baffle on which I impose a pressureJump. (I originally did it with cfMesh and we thought maybe it was the origin of the problem but I found the same thing with snappy). The two cases with mesh parameters and output (especially checkMesh but I cannot provide the mesh nor the geometry) are available in the dropbox folder. with CfMesh I use this mesh dict https://www.dropbox.com/s/vwl5wkdabcbz15s/meshDict?dl=0 and after my mesh was created I used the createBaffles utility using a .stl file from Salome to represent my rotor disk and the following createBafflesDict https://www.dropbox.com/s/mtpa3z7ces...fflesDict?dl=0. On the patches created with this utility I applied a pressure jump (or in the case in the dropbox a groovyBCJump to get a radially non uniform pressure jump, but I ran other case with cfMesh with fixed Jump and I got the same problems). with SnappyHexMesh I adapted the use case from https://www.erikrotteveel.com/tag/ducted-fan/: during the volume mesh I created a faceZone from a .stl file in the snappyHexMeshDict https://www.dropbox.com/s/es2ntrz42w...xMeshDict?dl=0 that I defined as a baffle, and from this face zone created patches to apply my cyclic pressure jump. Simulation For the two cases solver parameters and output are available in the dropbox folder. Observation Pressure Jump Errors After running with simpleFoam I realised that on some points of the baffle the pressure jump was not properly implemented : to observe this I got pressure values on FanIn and FanOut from paraview, compare them and marked in picture 3 points for which the deltaP between the two patches was not equal to the pressure jump I imposed. picture 3 at (https://www.dropbox.com/s/cxxqz6cma2...ition.JPG?dl=0) Note: Pictures 2 and 3 are taken from the snappyHexMesh case but same irregularities were found with cfMesh (c.f. picture 4 and 5) Faces Orientation In another post I saw that wrong faces orientation could trigger these issues but it does not seem to be the case here (checked with paraview filter 'generate surface normals') Questions
