cannot visualize the lagrangian data using Paraview from OpenFOAM 5.0 |
June 3, 2018, 11:56 |
Rep Power: 14 |
When I load the lagrangian data generated OpenFOAM 5.x, I always meet a problem from the data about the particle position. Since OpenFOAM 5.0, it seems that new algorithms have been used for lagrangian particle tracking: https://cfd.direct/openfoam/free-sof...tric-tracking/. However, it makes the particle date visualization a little bit difficult. I am not sure if any of you also have the same problem. I attached the snapshot here and please check that. I directly run "paraFoam" in the working directory, and the version of paraview is 5.4.0. Thanks! OFFO |
June 4, 2018, 03:25 |
Yan Zhang
Rep Power: 11 |
I have met this before.
You should use paraFoam in OF-5.0.
https://openfoam.top |
June 4, 2018, 03:27 |
Rep Power: 14 |
Thank you very much. Which version did you use for OpenFOAM 5.0? The source pack?
There are several from the below link: https://openfoam.org/version/5-0/ Thanks! |
June 4, 2018, 03:32 |
Yan Zhang
Rep Power: 11 |
I used this: sudo apt-get -y install openfoam5
And I think others are OK.
June 4, 2018, 03:34 |
Rep Power: 14 |
June 4, 2018, 03:39 |
Yan Zhang
Rep Power: 11 |
I have tried both. Both are OK!
June 4, 2018, 03:41 |
Rep Power: 14 |
June 4, 2018, 12:16 |
Rep Power: 14 |
Hi Zhang Yan,
I tried to install ubuntu on Win 10, following the procedures given here: https://openfoam.org/download/windows-10/ Everything is fine now. When I tried to run one tutorial in OpenFOAM 5.0, I go the attached error about write permission. Did you also have this issue? How did you resolve this? Thanks! |
June 4, 2018, 21:45 |
#9 |
Yan Zhang
Rep Power: 11 |
Sorry, I didn't have the same problem.
June 5, 2018, 02:10 |
#10 |
Rep Power: 14 |
September 11, 2019, 09:11 |
#11 |
Joaquín Aranciaga
Rep Power: 7 |
Hi! For future interested readers, here is the solution for the problem you posted:
Writing the old 'positions' file in Lagrangian solvers as of OpenFOAM 5.x Joaquín |
[OpenFOAM] how to visualize mapped data using ParaView | ggulgulia | ParaView | 2 | April 16, 2019 04:40 |
Visualize Star-CCM+ data in Paraview | peresah | STAR-CCM+ | 3 | April 9, 2019 03:25 |
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 05:48 |
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 | ad2eb | OpenFOAM Installation | 12 | May 28, 2017 14:30 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
