September 11, 2019, 16:08 |
Error while running OpenFoam
maryam shademani
Rep Power: 7 |
Dear All,
I would be thankful if you could help me to know how to fix the error I faced in OpenFoam. the error is as folowing: FOAM FATAL ERROR: [3] LHS and RHS of - have different dimensions dimensions : [0 1 -2 0 0 0 0] - [1 -2 -2 0 0 0 0] [3] [3] [3] From function Foam::dimensionSet Foam:perator-(const Foam::dimensionSet&, const Foam::dimensionSet&) From function Foam::dimensionSet Foam:perator-(const Foam::dimensionSet&, const Foam::dimensionSet&) [0] in file dimensionSet/dimensionSet.C at line 521. |
September 12, 2019, 03:47 |
Greetings Philipp Conen |
September 12, 2019, 12:24 |
maryam shademani
Rep Power: 7 |
Hi Philipp
thank you for your replying. Do you know how can I find which parameter has a wrong dimension.Or which equation has been set wrongly? Best Shadi |
September 13, 2019, 08:11 |
anonymous
Rep Power: 14 |
Hi!
I think the easiest way for that is finding a tutorial with the same solver, and compare the dimensions of your files in the 0 folder. You have a wrong dimensions in your 0 folder for any fields. At least usually this is the reason for these errors. |
September 13, 2019, 13:41 |
maryam shademani
Rep Power: 7 |
Thank you Simrego,
I exactly used the dimension which are proposed in the solver. Actually I am using two solvers, So that s why the dimensions are different. I am interseted in coupling interFoam with immersed boundary. Best |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
[Other] Basic questions about OpenFOAM cluster running and installing | Fauster | OpenFOAM Installation | 0 | May 25, 2018 15:00 |
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
Difficulty running an inviscid compressible nozzle flow using OpenFOAM | rbozinoski | OpenFOAM Running, Solving & CFD | 11 | December 29, 2015 07:19 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
