how to simulate ( air + sand ) flow in openFoam ?
Old   October 7, 2019, 06:40
Default how to simulate ( air + sand ) flow in openFoam ?
Os
losiola is on a distinguished road
hello guys
I want to make simualtion where i have air with sand particles on it
Do you have any idea about how to do that ?!!
Many Thanks
losiola is offline   Reply With Quote
Old   October 7, 2019, 11:35
clapointe is on a distinguished road
Check out sedFoam -- it might be useful for you : https://github.com/SedFoam/sedfoam.
Caelan
clapointe is offline   Reply With Quote
Old   October 7, 2019, 13:12
Os
Caelan
Hi
Do you have any other suggestions Beacause it is mentionned that it's not fully operationnel and i dont want to test it Real CAse CFD.
Old   October 7, 2019, 13:43
I don't know what you mean by "real case cfd", but I would check out the sedFoam thread (sedFoam: two-phase flow sediment transport model). You might get different information there.
Caelan
Old   October 7, 2019, 14:08
Os
Caelan
what i mean is that i dont want to fall in a senarion where the code still have bugs or maybe some errors that may lead me to innaccurate results or throught problems that i dont have time for . That's why i d prefer to use something that people already used before and made simulations with ..anyways i still gonna check the link and i really thank you for the reply .
Old   October 11, 2019, 18:17
Ash Kotwal
Ash Kot is on a distinguished road
There are two ways to simulate the sand + air, in other words, physics and math based meaning solid + gas flow.
1. Eulerian mathematical framework.
That's, following arbitrary amount of fluid particles and simulating flow.
2. Lagrangian mathematical framework.
In terms of Euler framework, you'll be using, Volume of Fluid (VoF). The solver for using VOF is 'interFoam', and its variants such as interDyMFoam, etc.
For solving flows with Lagrangian framework, the particles are assisted along a specific finite volume domain.
Procedure to follow:
1. Simulate the exiting tutorials in 'interFoam', and 'twoPhaseEulerFoam' or Lagrangian folder tutorials such as the parcelFilmFoam.
2. modify the case with respect to your desired conditions, starting with '0' folder, that is modify the patch fields for boundary conditions.
3. Next modify the physical properties/ transport properties, choose non-newtonian model for transport model.
4. If needed then implement inter-granular models as well.
5. Run the case as the geometry requirement.
Ash Kot is offline   Reply With Quote
Old   October 12, 2019, 04:34
Os
Hello ,
Thank you for the answer it's really helpfull
have a great day
Use OpenFOAM to simulate Knocking combustion in IC engine fcl OpenFOAM 2 March 6, 2018 04:02
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
Phasors in OpenFoam to simulate AC current flow Nicole OpenFOAM 0 February 11, 2015 02:55
