ACMI interface problem with multiphase field
Old   October 9, 2019, 13:34
Default ACMI interface problem with multiphase field
shach
shach934 is on a distinguished road
Hello Foamers,
I am using interFoam to solve a mixing tank problem. There is air and fluid. There is a tube around the propeller, so I am using the ACMI to acount for the interface for dynamic cellZone. However, the phase field solved at the ACMI boundary is not physical. I think it is something similar to the following bug report:
https://bugs.openfoam.org/view.php?id=1335#c3711
Here two problems were reported, for T and alpha.water. I am wandering if this is a bug or a case setup problem? And according to the record, this problem has not been fixed by the update provided.
Any hint is highly appreciated!
shach934 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
