shach
Rep Power: 8 ![]() |
Hello Foamers,
I am using interFoam to solve a mixing tank problem. There is air and fluid. There is a tube around the propeller, so I am using the ACMI to acount for the interface for dynamic cellZone. However, the phase field solved at the ACMI boundary is not physical. I think it is something similar to the following bug report: https://bugs.openfoam.org/view.php?id=1335#c3711 Here two problems were reported, for T and alpha.water. I am wandering if this is a bug or a case setup problem? And according to the record, this problem has not been fixed by the update provided. Any hint is highly appreciated! |
Display Modes | |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
