June 23, 2020, 21:39 |
Boundary condition w/o wall function
moon
Rep Power: 6 |
how can i set the boundaryfield in 0 folder(nut, omega, k) , if i don't want to use wall function for several boundaries???
I'm using kwsst model and It seems that k, nut, omega field might be changed respectively in different ways . |
June 26, 2020, 02:11 |
Rep Power: 8 |
did you try fixed value with a value of 1e-18 or another low value, or even 0 at those boundaries?
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
