Question about 3D circular cylinder case
Old   November 20, 2019, 06:59
Default Question about 3D circular cylinder case
Tian-xiong Zhao
Lanius is on a distinguished road
Hello.
I have did a case which involves flow past a 3D circular cylinder through icoFoam. It runs well, and the vortex shedding form agrees previous research well.
However, when I changed the "convert to meter" in the blockMesh.dict from "0.001" to "0.01",which was supposed to enlarge the whole model 10 times, the vortex shedding phenomenon disappear. The fluid field appear to follow a lower Reynolds number form.
Should't the Reynolds number increased because of the increase of cylinder diameter?
Lanius is offline   Reply With Quote
Old   November 26, 2019, 05:19
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
Originally Posted by Lanius View Post
Hello.
Did you increase the cell refinement as well, when you increased the domain size?
Rasmusiwersen is offline   Reply With Quote
[Gmsh] 3D Free surface flow past circular cylinder meshing using GMSH arieljeds OpenFOAM Meshing & Mesh Conversion 7 January 14, 2017 12:57
water rivulet on a circular cylinder kkpal OpenFOAM Running, Solving & CFD 0 December 3, 2015 23:53
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
3D Circular Cylinder..please help Endee FLUENT 3 September 5, 2005 14:46
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
