Help - to understand physical reality of numerical equations !!! |
January 9, 2020, 04:46 |
#1 | |||
Hello Foamers,
I have 2 equations to solve for 2 variables - pressure (p) and velocity (V) Used --> del - nabla operator, dow - partial derivative term Quote:
By applying the operator (del X) cross product on Eq. (2), Quote:
(1) When expanding Eq. (3), [First term + Second term] L.H.S - First term, (del X V) = Curl = [ (dow vy/dow x) - (dow vx/dow y) ] L.H.S - Second term, it can be expanded in 2 ways, MATRIX FORM: ( V X del (ln(f1+f2*V)) =dow /dow y [ ln(f1+f2*vy) ]*vx - dow /dow x [ ln(f1+f2*vx) ]*vy --> Eq. (5) GEOMETRIC FORM: ( V X del (ln(f1+f2*V)) = (V) ( del (ln(f1+f2*V) ) sin (theta) In which of the two forms, second term can be expanded ? However, when expanding Eq. (3) as above first and second terms, it looks like a SINGLE EQUATION. So, how come its possible to obtain velocities vx and vy (2 variables) from one equation ? (2) When expanding Eq. (4), In R.H.S - First term, del.(rho*V) =RRg (substituted from CONTINUITY Eq. (1)) In R.H.S - Second term, Dot product is used - so cos (0)= 1 (Along x) and cos (90) = 0 (Along y) (dow2p2/ dowx2) = -(f1+f2*(rho*vx)) RRg - (rho*vx)* dow/dowx (f1+f2*(rho*vx)) //partial derivative (dow2p2/ dowy2) = -(f1+f2*(rho*vy)) RRg, //here second term is zero since cos 90 = 0 Pressure is a scalar quantity, from above 2 equations of (dow2p2/dowx2) and (dow2p2/dowy2), one equation is enough to calculate pressure. So, which one equation from 2 can be chosen optimistically ? My above questions might be rather trivial, but for some reason I can't seem to get this work done. Kindly correct me if I'm wrong somewhere in expanding equations. Kindly someone explain the physical reality of above numerical equations.. Thank you **The above equations are from the following reference: https://aiche.onlinelibrary.wiley.co.../aic.690200519 Last edited by Kummi; January 9, 2020 at 07:40. |
Fundamental questions about numerical schemes | Obad | OpenFOAM Running, Solving & CFD | 1 | May 10, 2021 10:40 |
Solving non-conservative equations | lost.identity | Main CFD Forum | 0 | July 14, 2010 06:15 |
Question about UDS equations | tstorm | Fluent UDF and Scheme Programming | 1 | January 11, 2010 13:04 |
Question about UDS equations | tstorm | FLUENT | 1 | January 11, 2010 13:02 |
New Books and Numerical Software | Eleuterio TORO | Main CFD Forum | 0 | December 18, 1998 12:41 |
