February 12, 2020, 07:52 |
fluid flow in a non-uniform duct
Priyanka P
Rep Power: 7 |
Hello Everyone,
I have question about modelling a fluid flow through a non-uniform duct. In my geometry, my fluid shape is as attached in the figure. The blue colored face is inlet and the pink colored face is outlet and fluid is air. As the shape of my fluid region is changing, so in this case how to find Reynold number to check whether my flow would be laminar or turbulent?? |
February 18, 2020, 18:25 |
Svetlana Tkachenko
Rep Power: 14 |
I would suggest to use the smaller pipes diameter as the characteristic length.
fluid flow, heat transfer, reynolds number |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 01:52 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 06:57 |
Compressible, buoyant BC for porous flow | vainilreb | OpenFOAM Pre-Processing | 0 | August 31, 2013 10:25 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
