ideasUnvToFoam ----> failed
Old   February 5, 2020, 00:15
Default ideasUnvToFoam ----> failed
Nic86 is on a distinguished road
Hello everyone,
I have a problem with the conversion of a mesh from UNV to Foam.
I meshed my geometry with Salome and everything seems to be fine.
Then, I exported the mesh as UNV file and used to command ideasUnvToFoam to export the mesh into openFoam format.
The following error displays (see below) and the mesh is not exported.
Anyone can help with this?
I have read that the ideasUnvToFoam utility has some bug, but i couldn't figure out how to solve it.
I'd need a step by step explanation ...
Thank you in advance
Nic
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-fa1285188035
Exec   : ideasUnvToFoam Mesh_1.unv
Date   : Feb 05 2020
Time   : 16:07:11
Host   : "nic-System-Product-Name"
PID    : 3353
I/O    : uncollated
Case   : /home/nic/Desktop/OpenFoam/Nic-6/run/3dChannel-Tutorial/3dChannel-highPressure
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 78987 points.
Processing tag:2412
Starting reading cells at line 157997.
First occurrence of element type 11 for cell 1 at line 157998
First occurrence of element type 41 for cell 4298 at line 170889
First occurrence of element type 111 for cell 95472 at line 353237
Read 394235 cells and 91174 boundary faces.
Processing tag:2467
Starting reading patches at line 1141709.
For group 1 named inlet trying to read 368 patch face indices.
For group 2 named outlet trying to read 274 patch face indices.
For group 3 named atmosphere trying to read 13603 patch face indices.
For group 4 named wall trying to read 75299 patch face indices.
Of 91174 so-called boundary faces 41854 belong to two cells and are therefore internal
Sorting boundary faces according to group (patch)
0: inlet is patch
1: outlet is patch
2: atmosphere is patch
3: wall is faceZone
Constructing mesh with non-default patches of size:
    inlet	368
    outlet	274
    atmosphere	13603
--> FOAM Warning :
    From function Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595
    Found 35075 undefined faces in mesh; adding to default patch.
Adding cell and face zones
 Face Zone wall 	75299
ideasUnvToFoam: ideasUnvToFoam.C:1277: int main(int, char**): Assertion `nouveau > -1' failed.
Aborted (core dumped)
Nic86 is offline   Reply With Quote
Old   February 5, 2020, 01:22
Hello again,
I understood that the problem was in the patch definition in salome: it is due to the fact that i have some internal walls.
how do you define zero width internal walls in salome to mesh and export to openFoam?
Thank you
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
