stitchMesh destroys AMR compatibility
Old   February 11, 2020, 09:09
Default stitchMesh destroys AMR compatibility
ma-tri-x is on a distinguished road
Hi everyone,
I want to share my finding:
Adaptive mesh refinement (compressibleInterDyMFoam) doesn't work when the mesh was created including stitchMesh.
Holds for foam-extend-4.0, foam-extend-4.1, OpenFOAM-7
Best regards
ma-tri-x is offline   Reply With Quote
Old   February 11, 2020, 09:48
anonymous
simrego is on a distinguished road
Hi!
Can you share a case for that? Or you could create a bug report.
But it should be ok. Since adaptive refinement is only works on pure hex cells, or polyhedron with history (from snappy for example). And just skip the other type cells...
simrego is offline   Reply With Quote
Old   February 11, 2020, 15:24
Hi!
Yes here is.
However, with the native foam-extend-4.1, compressibleInterDyMFoam, I get floatingPointExceptions when solving the p-eqn. With my highly modified version, it "worked". So stitchMesh is a secondary issue. Couldn't get compressibleInterFoam to run with the sample_case, maybe you do.
[mesh manipulation] stitchMesh perfect vs partial Eloise OpenFOAM Meshing & Mesh Conversion 2 October 25, 2017 10:47
[mesh manipulation] stitchMesh: multiple meshes GerhardHolzinger OpenFOAM Meshing & Mesh Conversion 3 August 25, 2017 12:43
How to apply AMR settings kahjoonyong CONVERGE 11 July 28, 2017 04:18
[mesh manipulation] StitchMesh sigFpe / bad point liquidspoon OpenFOAM Meshing & Mesh Conversion 2 November 29, 2015 14:19
[mesh manipulation] stitchMesh questions JulytoNovember OpenFOAM Meshing & Mesh Conversion 0 December 18, 2013 01:45
