nagetive time marching, ggi patch, rotating frame.
Old   February 9, 2020, 20:29
Default nagetive time marching, ggi patch, rotating frame.
Bidesh Sengupta
BSengupta is on a distinguished road
Hi Foamers!
I am trying to simulate a rotating wing with a fixed rpm. Schematic of my problem is attached.
When I am trying to run the simulation, it giving negative time.
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh turboFvMesh
Initializing the GGI interpolator between master/shadow patches: RotorGGI/StatorGGI
Turbomachine Mixer mesh:
    origin: (0 0 0)
    axis  : (0 0 1)
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Allocating field rho
Reading field U
Creating MRF model
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model laminar
Create Riemann solver
Allocating field rhoU
Allocating field rhoE
Allocating physDeltaT list for RK and Dual-Time Stepping
Creating oldTime fields for dual-time stepping
Starting time loop
Creating ggi check function object
Moving Cell Zone Name: cellRegion0 rpm: 1250
Moving Cell Zone Name: cellRegion1 rpm: 0
Moving Face Zone Name: RotorGGI_faces rpm: 1250
 Time = -0.0008517870533
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
bounding rho, min: -8002.780332 max: 1126.854835 average: 0.2519080825
new min: 0.8002967477
new max: 1.999596239
bounding rhoE, min: -2413391697 max: 338960313.3 average: -24780.12515
new min: 50034.0114
new max: 999650.5291
bounding U max: 16551.47357
bounding h, min: -710.4404189 max: 907465.0083 average: 306656.9902
new min: 10023.24515
bounding p, min: 2675.587422 max: 401158.8261 average: 104114.4592
new min: 10000.03539
rho L2 Residual: 4.806956853
 rho LInf Residual: 6.972972733
My boundary file is:
RotorGGI
type ggi;
nFaces 21232;
startFace 36777457;
rotationAxis (0 0 1);
nCopies 30;
shadowPatch StatorGGI;
zone RotorGGI_faces;
bridgeOverlap true;
blade
type wall;
nFaces 1135638;
startFace 36798689;
farfield
type patch;
nFaces 60000;
startFace 37934327;
StatorGGI
type ggi;
nFaces 38736;
startFace 37994327;
nCopies 30;
shadowPatch RotorGGI;
zone StatorGGI_faces;
bridgeOverlap true;
Have anyone encountered this kind of problem before. If anyone can give me a clue about this, I shall be really helped.
Thanks a lot for your time.
BSengupta is offline   Reply With Quote
Old   February 11, 2020, 14:17
HPE
Herpes Free Engineer
HPE is on a distinguished road
wow, time travel with OpenFOAM! OpenFOAM is very powerful as always.
Could you please provide a test case, so that we can replicate the reported issue?
Kind regards,
HPE
The OpenFOAM community is the biggest contributor to OpenFOAM; not person A or B. Let's report bugs or issue feature requests in GitLab-OpenFOAM.
Please `design` your questions well. Such effort always pays off well for inquirers and `helpmate`s:
How to create a Minimal, Reproducible Example,
How to give enough info to get help.
HPE is offline   Reply With Quote
Old   February 12, 2020, 03:18
Bidesh Sengupta
HI,
Many thanks for your reply.
Just few observations that I made.
The case is running well with rhoPimpleDyMFoam.
But I wish to run this case with dbns solver so I tried transonicMRFDyMFoam, this creates all the problem, although I could run a simple case withis solver. (Figure attached.)
I am trying to verify Caradonna Tung case. The solver ran well for very small time and suddenly went to negative time and crashed.
GGI pair (cylr, cyls)
Area: 1.275277793 1.277828438 Diff = -0.002550645763 or 0.1996078414 %
Flux: 5.127987472 5.377813765 Diff = -0.3272316814 or 6.381288627 %
GGI pair (discrl, discsl)
Area: 5.30890084 5.31952395 Diff = -0.01062311045 or 0.199700397 %
Flux: 56.36113422 56.36637665 Diff = -0.01146315011 or 0.02033874987 %
GGI pair (discru, discsu)
Flux: 50.45643701 50.43524362 Diff = -0.01267533051 or 0.02512133488 %
 Time = 4.508921598e-06
rho L2 Residual: 3.46313128
rho LInf Residual: 4.763521822
BiCGStab:  Solving for epsilon, Initial residual = 0.9999950781, Final residual = 2.212067388e-14, No Iterations 1
BiCGStab:  Solving for k, Initial residual = 0.008327140338, Final residual = 2.044108189e-16, No Iterations 1
    ExecutionTime = 78.21 s
Flux: 5.131371036 5.386445304 Diff = -0.337659898 or 6.580305646 %
Flux: 56.36112165 56.36636457 Diff = -0.01147948593 or 0.0203677386 %
Flux: 50.45640114 50.43519843 Diff = -0.01269114308 or 0.02515269182 %
 Time = -0.0002009053193
bounding rho, min: -19.10611878 max: 40.90783651 average: 0.9802035543
new min: 1e-06
new max: 9.999680957
bounding rhoE, min: -7694045.878 max: 17575530.49 average: 217490.5868
new min: 10000
new max: 1000000
bounding U max: 1.105151028e+10
bounding h, min: -693476.5548 max: 9.102065628e+11 average: 59528188.91
new min: 10000
new max: 100000000
rho L2 Residual: 3.456650242
rho LInf Residual: 4.787876414
BiCGStab:  Solving for epsilon, Initial residual = 0.9999999522, Final residual = 4.955930645e-12, No Iterations 1
BiCGStab:  Solving for k, Initial residual = 0.1883215581, Final residual = 6.680483789e-12, No Iterations 1
    ExecutionTime = 88.02 s
Flux: 5.598183521 5.294696389 Diff = -0.2341575821 or 4.182742156 %
Flux: 56.35205222 56.35510544 Diff = -0.01107282278 or 0.01964936918 %
Flux: 50.26947062 50.25606473 Diff = -0.01603900949 or 0.03190606405 %
 Time = -0.006116840835
[bidesh:26460] *** Process received signal ***
[bidesh:26460] Signal: Floating point exception (8)
[bidesh:26460] Signal code:  (-6)
[bidesh:26460] Failing at address: 0x3e80000675c
[bidesh:26460] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f6deb858f20]
[bidesh:26460] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f6deb858e97]
[bidesh:26460] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f6deb858f20]
[bidesh:26460] [ 3] /home/bidesh/foam/bidesh-4.0/lib/linux64GccDPOpt/libGodunovFlux.so(_ZNK4Foam10roeALEFlux12evaluateFluxERdRNS_6VectorIdEES1_ddS3_S3_ddddddS3_dS3_d+0x440)[0x7f6ded86d140]
[bidesh:26460] [ 4] transonicMRFDyMFoam(+0xac444)[0x563f19f38444]
[bidesh:26460] [ 5] transonicMRFDyMFoam(+0x3b68c)[0x563f19ec768c]
[bidesh:26460] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f6deb83bb97]
[bidesh:26460] [ 7] transonicMRFDyMFoam(+0x40aba)[0x563f19eccaba]
[bidesh:26460] *** End of error message ***
[bidesh:26456] *** Process received signal ***
[bidesh:26456] Signal: Floating point exception (8)
[bidesh:26456] Signal code:  (-6)
[bidesh:26456] Failing at address: 0x3e800006758
[bidesh:26456] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f21dbd3cf20]
[bidesh:26456] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f21dbd3ce97]
[bidesh:26456] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f21dbd3cf20]
[bidesh:26456] [ 3] /home/bidesh/foam/bidesh-4.0/lib/linux64GccDPOpt/libGodunovFlux.so(_ZNK4Foam10roeALEFlux12evaluateFluxERdRNS_6VectorIdEES1_ddS3_S3_ddddddS3_dS3_d+0x440)[0x7f21ddd51140]
[bidesh:26456] [ 4] transonicMRFDyMFoam(+0xac444)[0x556f1e0b2444]
[bidesh:26456] [ 5] transonicMRFDyMFoam(+0x3b68c)[0x556f1e04168c]
[bidesh:26456] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f21dbd1fb97]
[bidesh:26456] [ 7] transonicMRFDyMFoam(+0x40aba)[0x556f1e046aba]
[bidesh:26456] *** End of error message ***
mpirun noticed that process rank 4 with PID 26456 on node bidesh exited on signal 8 (Floating point exception).
May I have your mail id as I cannot upload my case here. My mail id is bideshsengupta.08@gmail.com
Thanks a lot.
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
