how to create Baffles?
Old   February 6, 2020, 18:22
Default how to create Baffles?
Nic86 is on a distinguished road
Hello everyone,
I am trying to create internal walls in my geometry and I understood they should be defined as Baffles.
I am using Salome to create the mesh and ideasUnvToFoam to export the mesh with the patches to openFoam.
However In my geometry I have internal walls that I don't know how to define: could anyone please tell me a step by step procedure to model internal walls?
Thank you
Nic86 is offline   Reply With Quote
[gmsh] How to create a 3D volume mesh using a existing surface mesh?! RobertHB Mesh Generation & Pre-Processing 0 July 20, 2017 08:12
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? keepfit OpenFOAM 4 February 19, 2017 14:40
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
