Applying restraints in openfoam
Hi foamers.
I am trying to attach a rope to the object in floating object sample in blueCFD 2017_2 (OF 5). I've added some lines to "dynamicMeshDict.sixDoF" file as below but it has no effect on the original tutorial answer. Does anyone have any Idea how to apply these kind of restrains? Code:
dynamicFvMesh dynamicMotionSolverFvMesh; |
Hello Taghi,
Have you checked your allRun script and dynamicMeshDict file to see if there is any reference to the "dynamicMeshDict.sixDoF" file somewhere? AFAIK, solvers only check for the constant/dynamicMeshDict, unless specified otherwise. My best bet is that your dynamicMeshDict.sixDoF is simply not used at all in the tutorial you're running, but it's here to offer another setup for dynamic mesh. Replace your current dynamicMeshDict file with the content of your dynamicMeshDict.sixDoF file and see if it solves your problem. Cheers, Yann |
Tnx a zillion times
"dynamicMeshDict.sixDoF" was meant to be replaced to "dynamicMeshDict". problem solved |
