July 13, 2010, 18:19 |
*.msh conversion + axissymetric problem
Abdel
Rep Power: 15 |
Hi everybody!!
I've converted a mesh (*.msh), it is an axissymetric problem (a barrel of a gun) but now after conversion i'm not sure that's a an axissymetric problem yet!! The wedge explanation on the user guide is not clear!! you can see my boundary file here http://www.4shared.com/file/nSG5aXjl/boundary.html How can I define a 2D an axissymetric problem, i have to define my symmetry axis (revolution axis) as a wedge? If yes how can i do it? Is there a tutorial case with an 2D axissymetric problem? Best regards!! |
July 13, 2010, 18:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Abdel,
I've been remembering about your posts about this, but never found the time again to try to answer them. Additionally, I have literally no experience in axisymetric cases, so that was another reason for not replying sooner . But since you opened a another thread, I remembered to search in the usual places:
Bruno
July 13, 2010, 19:37 |
Abdel
Rep Power: 15 |
Thanks Bruno for your response hope that can help me!!
July 14, 2010, 03:30 |
Rep Power: 15 |
hi bruxellois4,
think you can not copy the fluent axissymetry-mesh directly to openfoam as a wedge mesh. either you create a new mesh with blockMesh or (i've never tried this) you create a mesh in gabit with the following rules (page 18) http://projekter.aau.dk/projekter/fi...784/Report.pdf i hope this helps PS: in this report has some other interesting information |
July 14, 2010, 07:41 |
Pei-Ying Hsieh
Rep Power: 18 |
Someone developed an utility called makeAxialMesh for OpenFOAM. It will convert a 2D mesh to an axi-symmetric mesh. Search makeAxialMesh on OpenFOAM wiki. You can download the code + some documentation on how to use it. It is quite straight forward. Pei |
July 14, 2010, 08:55 |
Rep Power: 15 |
hi phsieh,
the link you are talking about is: http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh this converts a 2D block mesh file (with parallel faces) into an wedge-mesh, but i don't think it can convert a fluent axissymetry-mesh to open-foam wedge. for the axissymetry-mesh the type "cyclic" must be taken. am i wrong with this? |
July 14, 2010, 12:20 |
Abdel
Rep Power: 15 |
I don't think that MakeAxialMesh works with openFOam 1.7.
I have to simulate a barrel of a gun, as you can see in screen shots (attachments), i have one cell thick in y i direction, but in my boundary file i don't see how to define a wedge, SO has an idea, help plzz 13 ( tube5 { type wall; nFaces 30; startFace 60334; } tube4 { type wall; nFaces 3; startFace 60364; } FREIN3 { type wall; nFaces 70; startFace 60367; } FREIN2 { type wall; nFaces 15; startFace 60437; } FREIN1 { type wall; nFaces 30; startFace 60452; } Frein { type wall; nFaces 20; startFace 60482; } Pressure_inlet { type patch; nFaces 30; startFace 60502; } Tube3 { type wall; nFaces 21; startFace 60532; } Tube2 { type wall; nFaces 10; startFace 60553; } Tube1 { type wall; nFaces 139; startFace 60563; } Axe { type symmetryPlane; nFaces 215; startFace 60702; } Pressure_outlet { type patch; nFaces 209; startFace 60917; } frontAndBackPlanes { type empty; nFaces 60730; startFace 61126; } ) |
July 14, 2010, 16:58 |
Pei-Ying Hsieh
Rep Power: 18 |
hi,
did you checkout the latest version from svn? It works for me on OpenFOAM-1.7.x. Pei |
July 14, 2010, 17:01 |
#9 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, bruxellois4,
I assume that your frontAndBackPlanes are the wedge BC. So, frontAndBackPlanes { type wedge; nFaces 60730; startFace 61126; } Pei |
July 14, 2010, 17:08 |
#10 |
Abdel
Rep Power: 15 |
Hi Pei,
i 've changed the frontAndBackPlanes to wedge type but that i didn't see any change under paraview i steel having the same graphics. Do you have any idea how to install MakeAxialMesh under OF 1.7! Thanks Abdel |
July 14, 2010, 19:25 |
#11 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, bruxellois4
In your 0/ folder, all variables, say p and U, you should also have frontAndBackPlanes set to wedge, for example, frontAndBackPlanes { type wedge; } -------------- I don't understand what you mean by you still have the same graphics under paraview. To install makeAxialMesh under OF-1.7.x, just download the latest version from svn (mentioned on the wiki page). Then, cd do the MakeAxialMesh folder, type ./Allwmake Good Luck! Pei |
July 14, 2010, 19:32 |
#12 |
Abdel
Rep Power: 15 |
[QUOTE=phsieh2005;267323]Hi, bruxellois4
In your 0/ folder, all variables, say p and U, you should also have frontAndBackPlanes -------------- I don't understand what you mean by you still have the same graphics under paraview. [/QUOTErmar Yes it's done but ididn' remark any change in graphics (paraview) withe empty patch or wedge, it 's the same regards Pei |
July 14, 2010, 19:42 |
#13 |
Abdel
Rep Power: 15 |
For makeAxialMess i've puted the folder under mesh/manipulation (makeAxialMes folder contain a folder (make) and a makeAxialMes.C file) i tried ./Alwemake but tha doesnt work.
1: wmake not found Abdel Last edited by bruxellois4; July 14, 2010 at 20:54. |
July 14, 2010, 21:33 |
#14 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Abdel,
When you check out the MakeAxialMesh files, you cd to MakeAxialMesh folder. You should have the following files/directories: TestCases (a folder) makeAxialMesh (a folder) Allwmake README type ./Allwmake in this folder. DO NOT cd to makeAxialMesh folder. Pei |
July 14, 2010, 21:35 |
#15 | |
Pei-Ying Hsieh
Rep Power: 18 |
[QUOTE=bruxellois4;267324]
Send it to phsieh2005@yahoo.com Pei |
July 14, 2010, 23:37 |
#16 | |
Abdel
Rep Power: 15 |
[QUOTE=phsieh2005;267337]
thank you Pei! |
November 26, 2010, 06:55 |
#17 |
Matthias Voß
Rep Power: 20 |
hi,
I am running OF 1.7.x. under suse, installed MakeAxialMesh without any problems. I’m facing some trouble whilst coming from msh. to a running axialmesh case using the makeAxialMesh tool. What i did so far: - created a quasi 2D Mesh in ICEM (1 cell height, frontandback in one patch, all patches are walls for now) --> exported to Fluent.V6 - used fluentMeshToFoam successfully -checkMesh ran without pointing out any mistakes - makeAxialMesh ran upto some fancy failure in "Attempt to cast type polyMesh to type fvMesh" AFTER successfully "copying patches ...." - the Output is pointing @ typeInfo.H (which is checking the types objects???) So. Anybody ever faced smth. similar? neewbie |
November 26, 2010, 07:03 |
#18 |
Matthias Voß
Rep Power: 20 |
me again,
i solved the problem by just simply deleting every .lib entry in my controlDict. neewbie |
March 5, 2020, 15:48 |
#19 |
Rep Power: 12 |
Hi!
For me, I changed Code:
if (!overwrite) { runTime++; } else { mesh.setInstance(oldInstance); } to Code:
if (!overwrite) { Info << "MK: runTime++ created corruptions. Therefore using -overwrite. sorry!" << endl; //runTime.functionObjects(); mesh.setInstance(oldInstance); Info << "MK: setting old instance" << endl; } else { mesh.setInstance(oldInstance); } in makeAxialMesh.C that solved it. but you can just override |
Display Modes | |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Unit Conversion Problem | lambuhere | CFX | 0 | August 20, 2004 04:49 |
