March 13, 2020, 07:09 |
K omega SST equations in Openfoam
Tom
Rep Power: 9 |
Hi All,
I'm looking at the k-mega SST equations for the value of omega in openfoam and i noticed that two different equations are used: The standard omega= k^0.5/CMu*L https://www.openfoam.com/documentati...omega-sst.html And theturbulentMixingLengthFrequencyInlet https://www.openfoam.com/documentati...frequency.html where omega is defined as omega =Cmu^0.75* k^1.5/L My question is why there are two different definitions of omega and which is correct to use for turbo-machinery internal flows? |
March 13, 2020, 23:49 |
Rep Power: 18 |
(k^3/2*cmu^3/4)/L is the expression for epsilon. Using SI units, it results m^2/s^3.
And I think that the other expression is wrong. Omega is equal to epsilon/(cmu*k). So, omega=k^1/2/(cmu^1/4*L). This expression results s^-1 in SI units. |
May 6, 2020, 09:41 |
#3 | |
Tom
Rep Power: 9 |
k-omega-sst, modelling, turbulence |
Inaccurate results for some turbulent annular flows using K-Omega SST | donree4 | OpenFOAM Running, Solving & CFD | 1 | March 19, 2019 18:15 |
K-Omefa SST DES in OpenFOAM | saiguruprasad | OpenFOAM Running, Solving & CFD | 0 | December 3, 2018 23:39 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
Fluent Turbulence equations to Openfoam equations | shovan | OpenFOAM Programming & Development | 0 | August 27, 2015 22:30 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
