Continue from previous log file
Old   September 21, 2010, 05:09
Default Continue from previous log file
Bernard Esterhuyse
bernarde is on a distinguished road
Hi all
I am look for a way to continue from my previous log file. Suppose I run a simulation for 2000 iteratins, using for example simpleFoam > log.
The simulation completes, and now I want to run for an additional 1000 iterations. Is there a way I can add these iterations to the first log file, or do I have to create an additional log file? If I run simpleFoam > log again, it overwrites the original log file, and the new one is only from iteration 2000 to 3000. I can do simpleFoam > log2, but then I have two logfiles, and I have to combine them to view residuals etc.
Is there a command to have the original log file appended with the new run data?
Regards
bernarde is offline   Reply With Quote
Old   September 21, 2010, 05:19
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Use:
instead of
Test it though to be sure...
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   September 21, 2010, 08:06
Bernard Esterhuyse
Thanks Laurence, that worked perfectly.
Old   March 17, 2020, 06:20
pranay
pranay347 is on a distinguished road
hi i tried that but it just adding the timesteps to the same file but its not staring from where it stopped, i mean it just starting from begining timestep by adding to the same file where it stopped. is there a way to start simulations from where it stopped?? i mean if the simulations stoped at 0.0106 deltaT but begin deltaT is 0.0002024, i want start simulation from deltaT =0.0106 not from 0.0002024?? can you tell me how to do that..Thanks in advance..
pranay347 is offline   Reply With Quote
Old   March 17, 2020, 08:49
Yann
Yann will become famous soon enough
Hi Pranay,
You just have to adjust the startFrom parameter in your controlDict file to latestTime.
Have a look at the documentation : https://cfd.direct/openfoam/user-guide/v7-controlDict/
startFrom Controls the start time of the simulation.
  • firstTime: Earliest time step from the set of time directories.
  • startTime: Time specified by the startTime keyword entry.
  • latestTime: Most recent time step from the set of time directories.
Cheers,
Yann
Yann is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 09:19
