kaboka |
March 24, 2020 07:47 |
ElevationVsTime OpenFOAM Sloshing motion
Hello everyone,
I got my free surface elevation values with the following code:
PHP Code:
functions
freeSurface
type surfaces;
functionObjectLibs
"libsampling.so"
outputControl outputTime;
outputInterval 1;
surfaceFormat vtk;
fields
alpha.water
surfaces
freeSurface
type isoSurfaceCell;
isoField alpha.water;
isoValue 0.5;
interpolate false;
regularise false;
interpolationScheme cell;
I wrote this code in controlDict and it worked. However, when I tried to plot the graph in python with the following code I'm getting OSError: coords not found. Could anyone tell me how can I add the coordinates in python. Reference website is:
HTML Code:
https://openfoamwiki.net/index.php/Tip_Surface_elevation_in_time
PHP Code:
#!/usr/bin/python
# elevationVsTime
# Read VTK files with isosurface
# Track one (x,z) coordinate in time
import os
import re
from vtk import *
from optparse import OptionParser
from numpy import *
print ("elevationVsTime")
# Read command line arguments
parser = OptionParser()
parser.add_option("-f","--input-file",dest="coords",type="string",help="Filename containing coordinates",metavar="FILE",default="coords")
(options, args) = parser.parse_args()
print ("Reading coordinates from file \"",options.coords,"\"")
f = loadtxt(options.coords)
#- Search starting point
x = f[:,0]
y = x*0+0.7
z = f[:,1]
points = len(x)
print (points," points found")
#- List input points
for i in range(0, points-1):
print ("Point ",i," (",x[i],",",z[i],")")
# Import timedirectories
# read the vtk directory and get all the time steps and return list
basedir = "freeSurface/"
timesteps=[]
for root,dir,file in os.walk(basedir,True):
p,time = os.path.split(root)
if (bool(re.search("^[0-9.]",time))):
timesteps.append(time)
filename = file[0]
basename = 'elevationVsTime'
timesteps = sorted(timesteps) # This sorts alphabetically
# "Progress-bar" necessity -
Ntimes = len(timesteps)
frac = round(Ntimes/10.0);
counter = 0
#- Time-info - known bug here
print ("Timerange: [",timesteps[0],",",timesteps[Ntimes-1],"]")
## Read
for ts in timesteps:
#- Counter info -- this info is approximate
counter = counter+1
if ( counter%frac == 0 ):
print (round(counter/frac)*10,"%")
#- Read VTK file
readfile = basedir + ts + "/" + filename
reader = vtkPolyDataReader()
reader.SetFileName(readfile)
reader.Update()
output = reader.GetOutput()
#- For each timestep, find the closest coordinate on the 0/ plane
for i in range(points):
writefile = basename + str(i)
file = open(writefile,'a+')
#- Coordinate to find closest point
xfind = [x[i], y[i], z[i]]
#- Find point
p = output.FindPoint(xfind)
#- Coordinate of point
xfound = output.GetPoint(p)
y[i] = xfound[1]
#- Write to file
print >> file, ts, y[i]
file.close()
Best regards
