resume simulation - p_rgh not stored
Old   June 25, 2020, 03:04
Default resume simulation - p_rgh not stored
Piotr Ładyński
piotr.mecht is on a distinguished road
I stopped my chtMultiRegionFoam simulation after 2 days to check, how the flow field progresses, but i can't resume it now form the latestTime.
Each core screams error:
[2] --> FOAM FATAL ERROR:
[2] previous iteration field
IOobject: volScalarField p_rgh local: "" readOpt: 0 writeOpt: 0 globalObject: 0 "/home/mecht/heater001/zoneSource/processor2/300/water"
  not stored.  Use field.storePrevIter() at start of iteration.
Is it possible to continue or do I have to start from the beginning? How is the time step 300 different to the timestep step 0, that I just can't start like it is 0? I copied my case with reconstructed 300 directory, then I tried to rename some files or to delete uniform folder, no effect.
Problem solved (logs, logs, logs!):
Initially (two days ago) i started my simulation with the same input for fvSolution for the water region and for the fvSolution in the system folder, then I realized, that the solver loops for unreasonable amounts of loops within the single timestep, because it solved pimple algorithm loops again over the solved pimple loops inside each region (?), or something like this. I changed my system/fvsolution pimple input to PIMPLE {//empty} and it worked just fine. I couldn't recall that change today, and it seems that my initial settings were required to initiate my simulation.
piotr.mecht is offline   Reply With Quote
Old   April 12, 2022, 15:36
Peter Forsyth
peterforsyth is on a distinguished road
I came across the same error message (using reactingParcelFoam). It seems it *can* be an issue with the URF field/equation names not being explicitly defined (see https://bugs.openfoam.org/view.php?id=895). I commented out everything inside the relaxationFactors dictionary in fvSolution, and it now seems to run.
Posting just in case anyone else comes across this issue.
peterforsyth is offline   Reply With Quote
How to resume a stopped simulation Pallav OpenFOAM Running, Solving & CFD 28 July 26, 2021 11:05
How to pause a transient simulation and resume without time step advancement? aleisia Main CFD Forum 33 June 12, 2017 11:41
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
Resume Transient simulation HMR CFX 1 June 28, 2011 21:13
