April 5, 2020, 14:09 |
Error: bouyantSimpleFoam command not found
Eduardo Miranda
Hi everyone!
I'm new using OpenFOAM and ubuntu's terminals as well. I've done simulations with IcoFoam and simpleFoam solvers, using the blockMesh dictionary and then tapping the solver command as you know. Actually, I'm trying to use the bouyantSimpleFoam solver and when I want to perform the simulation, the terminal sends me the following message: "Command 'bouyantSimpleFoam' not found, did you mean: command 'bouyantSimpleFoam' from deb openfoam Try: sudo apt install <deb name>" And that's my problem, I don't know what to do actually. Thanks in advance if somebody knows how to fix it. Regards! |
April 6, 2020, 05:03 |
Yann
Rep Power: 26 |
Hi Eduardo,
There is a typo in your command. The proper solver name is "buoyantSimpleFoam". When you bump into the "command not found" error there are mostly two possibilities :
Cheers, Yann |
command, error, openfoam, solver, ubuntu |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
