Error: bouyantSimpleFoam command not found
Hi everyone!
I'm new using OpenFOAM and ubuntu's terminals as well. I've done simulations with IcoFoam and simpleFoam solvers, using the blockMesh dictionary and then tapping the solver command as you know. Actually, I'm trying to use the bouyantSimpleFoam solver and when I want to perform the simulation, the terminal sends me the following message: "Command 'bouyantSimpleFoam' not found, did you mean: command 'bouyantSimpleFoam' from deb openfoam Try: sudo apt install <deb name>" And that's my problem, I don't know what to do actually. Thanks in advance if somebody knows how to fix it. Regards! |
Hi Eduardo,
There is a typo in your command. The proper solver name is "buoyantSimpleFoam". When you bump into the "command not found" error there are mostly two possibilities :
Cheers, Yann |
