April 20, 2020, 10:33 |
Foam-extension 4.1 installation error
Elaxender david
Rep Power: 8 |
Hi
Please I need help I tried to install foam-extension 4.1 on Kubuntu 19.10 and ubuntu19.10 and ubuntu 18.04 and linuxmint 18.3 many times, but got error. The error message as :- Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: san-VPCEH3QFX OS: Linux version 5.3.0-46-generic ------------------------------------------------------------------------------- Checking main foam-extend env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/san/foam yes yes $WM_PROJECT_USER_DIR /home/san/foam/san-4.1 no no $WM_THIRD_PARTY_DIR .../san/foam/foam-extend-4.1/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the foam-extend env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/san/foam/foam-extend-4.1 yes yes yes $FOAM_APPBIN ...pplications/bin/linux64GccDPInt32Opt yes yes yes $FOAM_SITE_APPBIN ...am/site/4.1/bin/linux64GccDPInt32Opt no no $FOAM_USER_APPBIN ...pplications/bin/linux64GccDPInt32Opt no no $WM_DIR /home/san/foam/foam-extend-4.1/wmake yes yes yes ------------------------------------------------------------------------------- Checking the foam-extend env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...-extend-4.1/lib/linux64GccDPInt32Opt yes yes yes $FOAM_SITE_LIBBIN ...am/site/4.1/lib/linux64GccDPInt32Opt no no $FOAM_USER_LIBBIN ...oam/san-4.1/lib/linux64GccDPInt32Opt no no $MPI_ARCH_PATH ...1.8.8/platforms/linux64GccDPInt32Opt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of foam-extend Supplied version: 4.3.3 User version : 9.2.1 Minimum required: 4.3.1 gcc 9.2.1 WARNING: Conflicting installations: foam-extend settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.10 /usr/bin/gzip tar 1.30 /usr/bin/tar icoFoam ...tend-4.1/applications/bin/linux64GccDPInt32Opt/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
April 23, 2020, 01:10 |
Andreas P.
Rep Power: 8 |
Everything seems fine. Try to execute some foam-extend application or solver, i think it should work.
I also got this "critical error" due to conflicting gcc installations, but everything worked as expected, so i did not bother to solve it. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
[OpenFOAM] Xwindows crash with paraview save | srinath | ParaView | 1 | October 15, 2008 09:37 |
