foam fatal error face is already marked for removal
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : blockMesh Date : May 15 2020 Time : 03:42:06 Host : LAPTOP-R02HBMJD PID : 582 I/O : uncollated Case : /home/pomogranade/prat/cavity nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const Foam::PtrList<Foam::dictionary>&, const Foam::word&, const Foam::word&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 867 Found 5 undefined faces in mesh; adding to default patch defaultFaces Check topology Basic statistics Number of internal faces : 0 Number of boundary faces : 30 Number of defined boundary faces : 30 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list... Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Block 0 cell size : i : 0.8 .. 0.8 j : 1 .. 1 k : 1 .. 1 Block 1 cell size : i : 0.2 .. 0.2 j : 1 .. 1 k : 0.4 .. 0.4 Block 2 cell size : i : 0.2 .. 0.2 j : 0.8 .. 0.8 k : 0.2 .. 0.2 Block 3 cell size : i : 0.2 .. 0.2 j : 1 .. 1 k : 0.4 .. 0.4 Block 4 cell size : i : 1.5 .. 1.5 j : 1 .. 1 k : 1 .. 1 Creating merge patch pairs Adding point and face zones Creating attachPolyTopoChanger --> FOAM FATAL ERROR: face 15 already marked for removal From function void Foam::polyTopoChange::removeFace(Foam::label, Foam::label) in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2844. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&)sh: 1: addr2line: not found addr2line failed #1 Foam::error::abort()sh: 1: addr2line: not found addr2line failed #2 Foam::polyTopoChange::removeFace(int, int)sh: 1: addr2line: not found addr2line failed #3 Foam::polyTopoChange::setAction(Foam::topoAction const&)sh: 1: addr2line: not found addr2line failed #4 Foam::slidingInterface::coupleInterface(Foam::poly TopoChange&) constsh: 1: addr2line: not found addr2line failed #5 Foam::slidingInterface::setRefinement(Foam::polyTo poChange&) constsh: 1: addr2line: not found addr2line failed #6 Foam::polyTopoChanger::topoChangeRequest() constsh: 1: addr2line: not found addr2line failed #7 Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool)sh: 1: addr2line: not found addr2line failed #8 Foam::attachPolyTopoChanger::attach(bool)sh: 1: addr2line: not found addr2line failed #9 ?sh: 1: addr2line: not found addr2line failed #10 __libc_start_mainsh: 1: addr2line: not found addr2line failed #11 ?sh: 1: addr2line: not found addr2line failed Aborted (core dumped) Can anyone explain why I am getting this error? blockMeshDict file is /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1; vertices ( (0 0 0) (0.8 0 0) (0.8 1 0) (0 1 0) //block1 (0 0 1) (0.8 0 1) (0.8 1 1) (0 1 1) (0.8 0 0) (1 0 0) (1 1 0) (0.8 1 0) //block2 (0.8 0 0.4) (1 0 0.4) (1 1 0.4) (0.8 1 0.4) (0.8 0.2 0.4) (1 0.2 0.4) (1 1 0.4) (0.8 1 0.4) //block3 (0.8 0.2 0.6) (1 0.2 0.6) (1 1 0.6) (0.8 1 0.6) (0.8 0 0.6) (1 0 0.6) (1 1 0.6) (0.8 1 0.6) (0.8 0 1) //block4 (1 0 1) (1 1 1) (0.8 1 1) (1 0 0) (2.5 0 0) (2.5 1 0) (1 1 0) (1 0 1) //block5 (2.5 0 1) (2.5 1 1) (1 1 1 ) ); blocks ( hex (0 1 2 3 4 5 6 7) (1 1 1) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (1 1 1) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (1 1 1) simpleGrading (1 1 1) hex (24 25 26 27 28 29 30 31 ) (1 1 1) simpleGrading (1 1 1) hex (32 33 34 35 36 37 38 39) (1 1 1) simpleGrading (1 1 1) ); edges ( ); boundary ( movingWall { type wall; faces ( (3 2 6 7) (35 34 38 39) ); } fixedWalls { type wall; faces ( (0 3 7 4) (0 4 5 1) (8 12 13 9) (16 20 21 17) (24 28 29 25) (32 36 37 33) (34 33 37 38) ); } frontAndBack { type wall; faces ( (3 0 1 2) (4 7 6 5) (11 8 9 10) (28 31 30 29) (35 32 33 34) (36 39 38 37) ); } interface1 { type wall; faces ( (1 5 6 2) ); } interface2 { type wall; faces ( (8 12 15 11) ); } interface3 { type wall; faces ( (16 20 23 19) ); } interface4 { type wall; faces ( (24 28 31 27) ); } interface5 { type wall; faces ( (32 36 39 35) ); } interface6 { type wall; faces ( (12 13 14 15) ); } interface7 { type wall; faces ( (16 17 18 19) ); } interface8 { type wall; faces ( (20 21 22 23) ); } interface9 { type wall; faces ( (24 25 26 27) ); } interface10 { type wall; faces ( (9 10 14 13) ); } ); mergePatchPairs ( (interface1 interface2) (interface1 interface3) (interface1 interface4) (interface6 interface7) (interface8 interface9) (interface10 interface5) ); // ********* // |
- The error comes from this source. - In `mergePatchPairs`, there seems to be non-mapping faces in corresponding patches. - Could you please double check `mergePatchPairs`? Hope this helps. |
