Can the set up files created for openfoam v7.0 (from .org) can be used for openfoam 1 |
January 10, 2020, 02:33 |
ijaz fazil
Rep Power: 13 |
I noticed that openfoam software is provided by two different organisations
1. ESI group 2. OpenFOAM foundation. My doubt is if the cases are set based on the version provided by openfoam foundation can be used for ESI group. |
January 10, 2020, 04:42 |
Rep Power: 12 |
Pardon my candidness but your question is depicting lack of effort and laziness... natural counter-questions would be: Firstly, do you have ESI development operational on your system? If yes, have you given it a shot? Did you run into issues with interchangeability? Why not post those (if any) issues?
On a slightly charitable note, the developments are 'largely' interchangeable in operation apart from few/rare syntactical differences but obviously have differences in development (additional solvers, discretization algorithms, etc.); both of which could generally be debugged/troubleshooted via output error messages. |
July 3, 2020, 09:33 |
ijaz fazil
Rep Power: 13 |
Dear fresty,
Thanks for your reply. It is not because of laziness I tried what you said. I run cases now both version and check the results. Previously I was using openfoam 4.0, a friend suggested ESI version is better for heat transfer analyses. So I just want to know others opnion also in case of shifting. Also in recent times I noticed the same cases while running ESI version was good while resulted in error in foundation version. Especially when I consider the effect of gravity in bouyant(boussinesq)simplefoam. |
openfoam, openfoam 1706, openfoam 1906, openfoam 4.0, openfoam 7 |
Linux was created in GAMBIT mesh files I have. | jlaclee | FLUENT | 0 | July 11, 2012 07:23 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
case files created by Setupgrid | Federico Salimbeni | FLUENT | 0 | June 21, 2002 05:54 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
