September 25, 2020, 04:37 |
error while running sprayFoam
Riddhideep Biswas
Rep Power: 5 |
Dear friends,
I am running a lagrangian simulation using sprayFoam solver and whenever I am trying to run it, I get an error as attached below. Can someone please tell me how to solve this error? Last edited by -mAx-; September 22, 2022 at 02:19. |
September 25, 2020, 06:03 |
Lucie Recurt
Rep Power: 5 |
Maybe you sould share your kinematicProperties file |
September 25, 2020, 07:07 |
attachment of sprayCloudProperties file
Riddhideep Biswas
Rep Power: 5 |
Thank you very much Lucie for your reply.
here below, I am attaching the google drive link of my whole sprayCloudProperties file https://drive.google.com/file/d/1Otl...ew?usp=sharing I have also attached a pic of the submodels part of my sprayCloudProperties file in case you face any problem with the link Last edited by -mAx-; September 22, 2022 at 02:19. |
September 25, 2020, 09:00 |
Lucie Recurt
Rep Power: 5 |
I don't see the problem... Did you compare your fvSchemes and fvSolution with the only s sprayFoam tutorial?
September 25, 2020, 09:14 |
Riddhideep Biswas
Rep Power: 5 |
Yes. I copied the fvSchemes and fvSolutions files of this simulation from the tutorial case.
September 27, 2020, 05:25 |
log of a standard tutorial (aachenBomb) is something like this; Code:
No finite volume options present Courant Number mean: 0 max: 0 Starting time loop compressibleCourantNo.H file calculate Courant number and involve the division (/) by rho. If rho is zero at anywhere, it will give you the error message you got. rho will be obtained by thermophysical properties model you used. Incorrect p and T may cause unrealistic rho. My recommendation is to check thermophysical model and settings, boundary conditions, and initial conditions. |
October 29, 2020, 02:19 |
Riddhideep Biswas
Rep Power: 5 |
Thank you very much Shinji for your reply.
I have another question. If I want to give an atmospheric boundary condition at the outlet of my domain, what value should I give in my p file? Should I give a value of 0 Pa(i.e. the gauge pressure) or should I give 1e5 Pa(i.e. the absolute value)? |
[OpenFOAM.org] Error running #codeStream/functions wmake lnInclude fails to open *.H Files | tarik | OpenFOAM Installation | 8 | June 14, 2020 03:12 |
Error Running Design of Experiments in ANSYS Fluent | tytrzecki | FLUENT | 0 | April 22, 2018 15:01 |
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS | JMosiezny | OpenFOAM Installation | 15 | December 9, 2017 08:20 |
Problem in running coarse mesh(on the other hand fine mesh is running) | ashokmoravaneni | OpenFOAM | 7 | July 17, 2017 04:56 |
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
