October 12, 2018, 05:36 |
Density-based vs Pressure-based solvers
Tommaso M.
Rep Power: 7 |
Hi All,
I have a question about compressible solvers. Could anyone know if RhoPimpleFoam is considered as a pressure-based or a density-based solver? Thank you in advance. |
October 19, 2018, 02:40 |
Cyprien
Rep Power: 18 |
It is a pressure-based solver because you solve an equation for the pressure. The solver is named rhoPimpleFoam because it handles compressible fluid and in this case the pressure equation depends on the time variation of the density (related to the time variation of the pressure using a compressibility factor).
Cheers, Cyprien
www.cypriensoulaine.com/openfoam |
October 19, 2018, 06:03 |
Tommaso M.
Rep Power: 7 |
Ok. Thank you very much for your help.
November 7, 2018, 10:29 |
#4 | |
Lucky
Rep Power: 65 |
Pressure-based vs density-based are historical names and really shouldn't be used anymore. And really it only comes up when someone is coming from a Fluent background. If you are asking if rhoPimpleFoam behaves more like Fluent's pressure-based or more like Fluent's density-based solver then the answer is that it is closer to Fluent's pressure-based solver.
You can get more precise answers by asking what is the exact technique used to solve the coupled set of pde's (continuity, momentum, energy, etc.). In Fluent, the pressure-based solver is a segregated solvers and density-based solver is a coupled solver. |
October 9, 2020, 05:44 |
#5 | |
Rep Power: 6 |
Dear Cyp, what do you mean with a compressibility factor? Bulk modulus, is it possible to adjust ? |
Density or Pressure based solver | Achu | FLUENT | 1 | April 27, 2018 04:34 |
Implement simple barotropic relation - derive density field from pressure field | GJM1991 | OpenFOAM Programming & Development | 6 | May 8, 2016 15:43 |
Pressure based vs density based solver | newbie384 | FLUENT | 2 | July 5, 2013 02:04 |
pressure correction scheme vs density based scheme | PCFD | Main CFD Forum | 0 | May 18, 2009 15:57 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
