Question about db().lookupObject<volScalarField>
Like Tree2Likes
  • 1 Post By simrego
  • 1 Post By simrego
Old   November 18, 2020, 06:17
Default Question about db().lookupObject<volScalarField>
user92 is on a distinguished road
Hello everyone,
I have a question about the line of code below which I found here in Line 84
const volScalarField& p = alpha1_.db().lookupObject<volScalarField>("p");
I couldn't find a clear explanation for it, so I supposed that db stands for a database in OpenFOAM? and the code is looking for "p" in <volScalarField>
I suppose further that <volScalarField> must come from an .H file which has "p" ... is this right? if yes, is the file volScalarField.H available somewhere?
Thank you
user92 is offline   Reply With Quote
Old   November 18, 2020, 07:47
anonymous
simrego is on a distinguished road
Hi!
after the "database" (db) is accessed, read like this: you are looking for an object (lookupObject), which is a volScalarField type (<volScalarField>), and called p ("p").
volScalarField is a typedef, it is a "shorter notation" of GeometricField<scalar, fvPatchField, volMesh>
It is defined here:
https://openfoam.com/documentation/g...ce.html#l00059
user92 likes this.
simrego is online now   Reply With Quote
Old   November 18, 2020, 08:55
Originally Posted by simrego View Post
Hi!
It is defined here:
Thank you I have a few more clarifications if I may ask
- I wonder if there is a link to the db where I can see all objects there including "p"?
- does <...> always describe types? or is it only a syntax for lookupObject<type>("object name")?
for example what you mentioned: GeometricField<scalar, fvPatchField, volMesh> ... does this mean that scalar, fvPatchField, volMesh are also types since they are inside <>? if yes, is is fine to have multiple types (3 in this case)?
Old   November 18, 2020, 09:23
anonymous
You can read a bit about the objectRegistry here:
https://openfoamwiki.net/index.php/O...objectRegistry
And for the <> stuff, this is called templating. You should dig into the C++ programming language for details.
user92 likes this.
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 05:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 11:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 14:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
