interFoam
Old   March 31, 2010, 11:23
Default interFoam
Andrea Pasquali
andrea.pasquali is on a distinguished road
I'd like to simulate a rotating gear system into oil. I choose the solver interFoam.
U: I compiled new BC to set a ramp of velocity of rotation (timeVaryingRotatingWallVelocity) for my rotating elements (http://www.cfd-online.com/Forums/ope...edvalue.html);
p: I used the totalPressure for the atmosphere patch and zeroGradient for all other walls and rotating element;
k-epsilon model for the turbulence.
First I tried with epsilon = 100 and my simulation died after 0.06 seconds.
Then I increased the value of epsilon = 1000 and my simulation died at 0.84 seconds.
I attached the plots of residuals and Courant number.
You can see that in the end of simulation k and epsilon start increasing very fast and bring the calculation to die in a very little time!
Now I'm thinking to run new analysis increasing the value of epsilon, but before I have some question:
1) Is it correct use k-epsilon for rotating element?
2) If yes, how can calculate the correct value of k and epsilon without find it by tentative? I try to use the formulas that are in OF user guide but I don't know how can use them with rotating elements or if are correct for rotating elements
Thanks anyone for any suggestion
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   May 10, 2010, 09:19
Andrea Pasquali
Hello I spent much time about my case,
I think I improved my analysis but I'm still far to obtain the correct solution.
The problem is I cannot extend the analysis longer than 1.04 sec.
I want explain my problem:
- My run looks good until 1.04 sec (it has "just" buonding k from 0.5 sec). I used ramp of velocity until 0.25 sec. You can see the residuals in the pictures I attached.
- Suddenly the calculation crash! I can see in the error message the rown "floating point exception".
- So, how I found in http://www.cfd-online.com/Forums/ope...implefoam.html , I commented the row //export FOAM_SIGFPE= in etc/bashrc file.
- Then I restart the analysis from 1.04 and this is what I obtain:
Courant Number mean: 0.0222972 max: 0.895581
deltaT = 0.000163178
Time = 1.05054
MULES: Solving for alpha1
Liquid phase volume fraction = 0.194044 Min(alpha1) = -1.51761e-20 Max(alpha1) = 1
Liquid phase volume fraction = 0.194043 Min(alpha1) = -1.54389e-20 Max(alpha1) = 1
Liquid phase volume fraction = 0.194043 Min(alpha1) = -1.70812e-21 Max(alpha1) = 1
GAMG: Solving for p, Initial residual = 0.0650721, Final residual = 9.71882e-08, No Iterations 22
GAMG: Solving for p, Initial residual = 0.0147061, Final residual = 9.55896e-08, No Iterations 20
GAMGPCG: Solving for p, Initial residual = 0.00283393, Final residual = 2.7137e-08, No Iterations 7
time step continuity errors : sum local = 2.74705e-11, global = 4.61938e-13, cumulative = -1.65011e-11
smoothSolver: Solving for omega, Initial residual = 0.0012319, Final residual = 3.73989e-07, No Iterations 6
smoothSolver: Solving for k, Initial residual = 0.000760956, Final residual = 9.41354e-07, No Iterations 14
bounding k, min: 7.9354e-16 max: 100 average: 0.209985
ExecutionTime = 4141.07 s ClockTime = 4166 s
Courant Number mean: 0.0222973 max: 0.898009
Time = 1.0507
Liquid phase volume fraction = 0.194043 Min(alpha1) = -1.85544e-20 Max(alpha1) = 1
Liquid phase volume fraction = 0.194042 Min(alpha1) = -1.56878e-21 Max(alpha1) = 1
Liquid phase volume fraction = 0.194042 Min(alpha1) = -6.60323e-21 Max(alpha1) = 1
GAMG: Solving for p, Initial residual = 0.0651744, Final residual = 5.8543e+44, No Iterations 1000
GAMG: Solving for p, Initial residual = 1, Final residual = 2.10904e+42, No Iterations 1000
GAMGPCG: Solving for p: solution singularity
time step continuity errors : sum local = 2.54116e+222, global = 2.54116e+222, cumulative = 2.54116e+222
smoothSolver: Solving for omega, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000
ExecutionTime = 5874.96 s ClockTime = 5900 s
Courant Number mean: 1.30829e+117 max: 1.25004e+229
deltaT = 2.34969e-234
Time = 1.0507
GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan, cumulative = nan
I think this is very stange.
Just in 1 iteration the p equation in the 2^ loop is not solved and in 3^ loop has "solution singulatiy", the time step continuity error grows up and I have "not a number" in k and epsilon!!!
Can anyone explain this?
Why I have this error?
Thanks
Andrea
Andrea Pasquali
Old   May 29, 2010, 09:36
Andrea Pasquali
I'm still trying with my model and with interFoam.
Now I try the BC "buoyantPressure" in p file for each patch, like in interFoam tutorial, instead of "zeroGradient".
If you see the alpha1 plot (attached) you can see that for "zeroGradient" alpha1 decrease, for "buoyantPressure" is costant (my model is a closed volume, no inlet no outlet and the liquid can't exit from the atmosphere patch).
I can't understand why...
The buoyantPressure BC is not for thermal analysis or where the density change?
Could anyone help me?
Thanks
Andrea
Andrea Pasquali
Old   May 30, 2010, 08:50
Claus Meister
idrama is on a distinguished road
The solving for alpha is okay. It is high likely that you face a convection-dominace. Have you tried or even applied flux limiter vor div(rho*phi,U) term? I not try as a guess limitedLinearV 1; Properly, this will avoid the blow up.
cheers
idrama is offline   Reply With Quote
Old   May 30, 2010, 08:52
Claus Meister
Addtionally, it seems that you carry out to less PISO loops. At this point in iteration, increase them to five. If you should have an orthogonal mesh then set non-Orthogonal-correction to zero otherwise 1 and try again.
Old   May 30, 2010, 09:56
Andrea Pasquali
Hi Claus,
thank you very much for your reply!
For div(rho*phi,U) I have "Gauss limitedLinearV 1"
For PISO loop I have:
nCorrectors 3
nNonOrthogonalCorrectors 0 --> This check is OK with checkMesh
nAlphaCorr 1
nAlphaSubCycles 3
cAlpha 1
Another thing, I saw the solution at 0.5 seconds:
with p zeroGradient I have a field from -1850 to +1880 Pa
with p buoyantPressure the field goes from -1850 to +3800 Pa
I don't know what is the correct way...
Can you help me?
Thanks
Andrea
Andrea Pasquali
Old   May 30, 2010, 12:20
Claus Meister
At now, I don't know it either. Could you please post your p file and alpha1 file; i'd like to take a look!
Old   May 30, 2010, 12:45
Andrea Pasquali
Hi Claus,
here "p"
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
shell
type zeroGradient;
//type buoyantPressure;
//value uniform 0;
walls
type zeroGradient;
//value uniform 0;
shaft
type zeroGradient;
//value uniform 0;
bearingA
type zeroGradient;
//value uniform 0;
bearingB
type zeroGradient;
//value uniform 0;
differentialGear
type zeroGradient;
//value uniform 0;
wheel1
type zeroGradient;
//value uniform 0;
wheel2
type zeroGradient;
//value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
and here "alpha1"
FoamFile
version 2.0;
format ascii;
object alpha1;
dimensions [0 0 0 0 0 0 0];
boundaryField
shell
type zeroGradient;
walls
type zeroGradient;
shaft
type zeroGradient;
bearingA
type zeroGradient;
bearingB
type zeroGradient;
differentialGear
type zeroGradient;
wheel1
type zeroGradient;
wheel2
type zeroGradient;
atmosphere
type inletOutlet;
inletValue $internalField;
value $internalField;
For p BC I used first "zeroGradient" and then "buoyantPressure".
Thank you
Andrea
Andrea Pasquali
Old   February 23, 2021, 12:06
Default residuals interfoam
Kil
Kil's Avatar
Serge
Kil is on a distinguished road
Hello every one!
I have use interFoam too and would like to plot residuals, Courant number and Y+.
Can you tell me how I may to make it correctly?
I red that there are many ways to do it, but i didn't understand none of them.
First of them is to use "foamMonitor" but in example there is only "p" and "u", but I need other residuals and Co and Y+.
Second way is to use "pyFoamPlotWatcher.py" but it didn't run on my system.I had get messages like "command not found". And also I don't understand how I can to save residuals in "logFile" when I using a script to run parallel interFoam....
Can anybody to help me on this theme?
P.S. I use Ubuntu 20.04.02 and OpenFoam 8 if it have a matter.
Kil is offline   Reply With Quote
Getting a concentration field around a bubble in InterFoam azman OpenFOAM Running, Solving & CFD 3 June 7, 2022 04:21
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 11:45
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
Interfoam... free surface simulation urgent lostin4ever Main CFD Forum 4 October 12, 2010 08:29
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
