Regarding the y+ function
Old   December 23, 2020, 06:15
Default Regarding the y+ function
Arijit Saha
ari003 is on a distinguished road
Hello everyone, its Ari here and I would like to have some suggestion from any profound CFD enthusiast. As per my theoretical knowledge is concerned with y+ value it is the dimensionless first cell center distance from the wall and it has a fixed value throughout the simulation time. But, when I used y-plus function by specifying it in controlDict it gave me the y-plus values as function of simulation time-steps.
https://www.openfoam.com/documentati...eld-yPlus.html
Can anyone tell me what does that physically means and which value of y-plus value should I consider to have an impression overall ?
ari003 is offline   Reply With Quote
Old   December 29, 2020, 06:14
Tobermory will become famous soon enough
Can I suggest that you read up more about what y+ is.
Correct that it's the normalised near wall distance, but not correct that it's a constant. In fact, the normalisation uses the wall shear stress (often expressed as the friction velocity, u*). Can you see now why this might change during the simulation?
Tobermory is offline   Reply With Quote
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
