January 7, 2021, 10:32 |
Naca0012 with rhoCentralFoam
Thibaut
Rep Power: 5 |
Hi, I'm trying to use rhoCentralFoam on the case aerofoilNACA0012 in order to compare the results with those obtained with sonicFoam.
Actually, I took the case from $FOAM_TUTORIALS/compressible/sonicFoam/RAS/aerofoilNACA0012. The application in ControlDict was rhoPimpleFoam. I changed it to sonicFoam. It worked. I then changed to rhoCentralFoam, added what was asked in fvScheme and after a few iterations, I have a negative temperature. As you could guess, I'm new to OpenFoam and I may not use the good way to work. How can I use the case to compare both solver ? It actually may not be exactly that case, I juste want a compressible turbulent case (the prism case gives me the same problem). Thanks |
How to apply a turbulence model to the rhoCentralFoam solver? | arussell92 | OpenFOAM Pre-Processing | 18 | July 25, 2022 04:26 |
Modify rhoCentralFoam: other equations of state | fivos | OpenFOAM Programming & Development | 5 | July 29, 2020 13:17 |
NACA0012 with rhoCentralFoam | praveen | OpenFOAM | 17 | July 5, 2018 05:49 |
Inviscid simulation in rhoCentralFoam | chencw | OpenFOAM Running, Solving & CFD | 0 | April 13, 2018 15:49 |
dynamic mesh refinement and rhoCentralFoam | ChrisA | OpenFOAM Running, Solving & CFD | 1 | March 21, 2013 08:00 |
