February 18, 2021, 00:12 |
Value of diffusion coeeficient
Harsh Hambar
I am modelling a continuous stirred tank reactor, with water, which has been simulated at steady state using simpleFoam. after the steady state is achieved, I wanted to calculate the RTD curve for this and the mean residence time for the same. I tried doing so with the help of scalarTransportFoam. I do not want diffusion, therefore I set the value of dT to zero, but the result that I get is wrong. I can say that the result is wrong because the inlet concentration is one with a step input of 1, therefore after some time the outlet concentration must be 1 but it is much lower than that. I would like to know why is this happening. The inlet is at the top right side and the outlet is on the bottom left of the tank. I have attached the concentration vs time plot at the outlet.
is it possible to define different mass diffusion coefficients in different zones? | Weiqiang Liu | Main CFD Forum | 0 | June 3, 2019 20:24 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
Harmonic average of Diffusion Tensors in Finite Volume Method | Yurie_Breschnef | Main CFD Forum | 4 | September 6, 2018 04:51 |
Diffusion in Porous Media | kdep | FLUENT | 1 | March 28, 2016 16:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
