Visualize scalarCodedSource in paraFoam
Like Tree2Likes
  • 1 Post By NiklasW
  • 1 Post By NiklasW
Old   April 12, 2021, 16:23
Default Visualize scalarCodedSource in paraFoam
Jonathan Wells
jdw135 is on a distinguished road
I'm coding a scalarCodedSource to use with my case, and I'm trying to visualize the results in paraFoam. Is there a way to make it write the result of the calculation at each time step?
Essentially, I am making the field
scalarField& qq = eqn.source();
qq += ...;
and I would like to visualize qq at each time step. Is there something I add to the fvOptions file?
jdw135 is offline   Reply With Quote
Old   April 13, 2021, 10:13
Jonathan Wells
Anyone? I know there has to be a way to do this.
Old   April 13, 2021, 11:58
NiklasW is on a distinguished road
Hi Jonathan,
I'm not sure, if it's the best solution, but this might work:
qq += ...;
volScalarField volqq = volScalarField::New("qq",mesh_, 0.0);
volqq.primitiveFieldRef() = qq;
volqq.write();
jdw135 likes this.
NiklasW is offline   Reply With Quote
Old   April 14, 2021, 11:18
Jonathan Wells
Originally Posted by NiklasW View Post
Hi Jonathan,
qq += ...;
volqq.write();
For whatever reason, that causes the solution to take much longer and won't load anything at all in paraFoam.
Old   April 14, 2021, 11:28
So it also doesn't create qq files in your time folders?
Old   April 14, 2021, 14:47
Jonathan Wells
It does, but now nothing else gets written to the time folders and when I try to open the case in paraFoam, it just hangs forever when I click apply.
Old   April 14, 2021, 18:52
Jonathan Wells
Correction*
I realized that your code was printing the qq field every time step, rather than every 500 like my controlDict file specifies. That's almost certainly the cause of the slowdown, as my time step is 1e-5 and I'm running for several seconds.
I guess I need to figure out how to make it write only at the same intervals as the rest of my data.
Old   April 15, 2021, 03:32
Ah, ok, I thought you wanted to write it at each time step
This should do it:
if (mesh_.time().writeTime())
        volqq.write();
jdw135 likes this.
Old   April 15, 2021, 15:09
Jonathan Wells
This should do it:
        volqq.write();
This worked perfectly! Thank you so much for the help!
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 3 December 3, 2020 06:21
[OpenFOAM.org] paraFoam Fatal Error upon run Gallienus OpenFOAM Installation 2 April 14, 2020 19:23
How to visualize cellSets in paraFoam with streamlines anon_q OpenFOAM Post-Processing 0 October 17, 2018 10:25
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
