Openfoam 2006 and 2012 PotentialFoam cylinder and pitzdaily tut_No Solution
Old   May 13, 2021, 16:43
Default Openfoam 2006 and 2012 PotentialFoam cylinder and pitzdaily tut_No Solution
bigoqwerty is on a distinguished road
Hello All,
I'm opening this thread as a last resort to solve the issue with potentialFoam with 2006 and 2012 versions.
I have to openfoam versions, both installed correctly with allias in bashrc so on.
Regarding Potential Flow problems, I try to solve Cylinder and pitzdaily tutorails but I got the similar problem that have no solution. (Meshing is good but no 1 file)
When I look at log.potentialFoam what I see is (I change directory with b.... so it is good)
Create time
Create mesh for time = 0
potentialFlow: Operating solver in PISO mode
Reading velocity field U
Constructing pressure field p
Constructing velocity potential field Phi
No MRF models present
Calculating potential flow
Using dynamicCode for functionObject error at line 52 in "/home/b...../cylinder/system/controlDict.functions.error"
Could not load "/home/b....../cylinder/dynamicCode/platforms/linux64GccDPInt32Opt/lib/liberror_4eb03d8667682af775b54aaa89d2d512b10350d5.so"
/home/b..../cylinder/dynamicCode/platforms/linux64GccDPInt32Opt/lib/liberror_4eb03d8667682af775b54aaa89d2d512b10350d5.so: cannot open shared object file: No such file or directory
Creating new library in "dynamicCode/error/platforms/linux64GccDPInt32Opt/lib/liberror_4eb03d8667682af775b54aaa89d2d512b10350d5.so"
as this problem occurs in both versions, I strongly believe it is my system that cause the issue, but I couldn't find a fix.
If you have any idea about the origin of the flaw and possible fix, thanks in advance
bigoqwerty is offline   Reply With Quote
cylinder, openfoam, potentialfoam, problem, tutorial
