Problem with blockMeshDict
Old   June 8, 2021, 12:48
Default Problem with blockMeshDict
Anjul Pandey
anjul is on a distinguished road
Hello everyone, I am trying to make a cylindrical mesh with a square inside it. I wrote the blockMeshDict file, reviewed it but still couldn't figure out the issue. My blockMeshDict file is:
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001; // meters
//Domain length
Length 150;
//Square inside cylinder
Spoint 1.0; //Square point
Mspoint -1.0; //Negative direction square point
//Points of cylinder
icpoint 10.0; //ic-> inner Circle
Micpoint -10.0; //M-> minus
//Interpolation points to make arc
apoint 14.14213562; //arcpoint
Mapoint -14.14213562;
vertices
//Bottom
(0 0 0) //0
//Inner Square
(0 $Spoint $Mspoint) //1
(0 $Mspoint $Mspoint) //2
(0 $Mspoint $Spoint) //3
(0 $Spoint $Spoint) //4
//Circle
(0 $icpoint $Micpoint) //5
(0 $Micpoint $Micpoint) //6
(0 $Micpoint $icpoint) //7
(0 $icpoint $icpoint) //8
//Top
($Length 0 0) //9
//Inner Square
($Length $Spoint $Mspoint) //10
($Length $Mspoint $Mspoint) //11
($Length $Mspoint $Spoint) //12
($Length $Spoint $Spoint) //13
//Circle
($Length $icpoint $Micpoint) //14
($Length $Micpoint $Micpoint) //15
($Length $Micpoint $icpoint) //16
($Length $icpoint $icpoint) //17
//Mesh resolution
Nsqy 20; //Number of cells in square in y direction
Nsqz 20; //Number of cells in square in z direction
Nax 100; //Number of cells in axial direction
blocks
hex (1 4 3 2 10 13 12 11) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1)
hex (1 5 8 4 10 14 17 13) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1)
hex (4 8 7 3 13 17 16 12) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1)
hex (3 7 6 2 12 16 15 11) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1)
hex (2 6 5 1 11 15 14 10) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1)
edges
//Bottom
arc 5 6 (0 0 $Mapoint)
arc 6 7 (0 $Mapoint 0)
arc 7 8 (0 0 $apoint)
arc 8 5 (0 $apoint 0)
//Top
arc 14 15 ($Length 0 $Mapoint)
arc 15 16 ($Length $Mapoint 0)
arc 16 17 ($Length 0 $apoint)
arc 17 14 ($Length $apoint 0)
boundary
inlet
type patch;
physicalType noParticleOutFlow;
faces
(1 2 3 4)
(1 5 6 2)
(2 6 7 3)
(3 7 8 4)
(4 8 5 1)
outlet
type patch;
physicalType particleOutFlow;
faces
(10 11 12 13)
(10 14 15 11)
(11 15 16 12)
(12 16 17 13)
(13 17 14 10)
side
type patch;
physicalType particleoutFlow;
faces
(5 14 15 6)
(6 15 16 7)
(7 16 17 8)
(8 17 14 5)
mergePatchPairs
I am getting this error:
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 1
From function void Foam::blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 217.
FOAM exiting
Any help would be appreciated.
anjul is offline   Reply With Quote
Old   June 9, 2021, 11:45
Default paraFoam -block
Rahul Vadrabade
Rvadrabade is on a distinguished road
I couldn't try at the moment but can you check that the topology of block is correct by defining a single hex block at a time, commenting other lines. Probably you can find clue to issue.
To check blocks are correct, try 'paraFoam -block'.
Rvadrabade is offline   Reply With Quote
Old   June 10, 2021, 05:37
Anjul Pandey
Thank you for your response. I tried what you said and found out the issue. It's in the way I was giving the cells in each direction. The correct way is:
($Nsqy $Nsqz $Nax)
in all hex cells as both Nsqy and Nsqz are 20.
blockmesh dict, meshing 3d, openfoam 5.x
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
