Initialization of internal field
Dear all,
I am a beginner of OpenFOAM. What I am trying to do is First, I run the simulation using 4m-length tube mesh. Create a new tube mesh with same diameter but longer.(6m-length) Copy the field values of result of 4m-tube simulation, to the 6m-length. Additional 2m is initialized any value that I want. Currently, how I am doing this : Copy the field value (at certain time step) from 1st simulation, and paste it to the 0 folder of longer tube. And then type in the values for all the cells of additional 2m. When grid number becomes large, this is very time-consuming. There might be an easier way to do this. Any help will be appreciated. Thank you! |
There is a mapFields utility which maps one or more fields relating to a given geometry onto the corresponding fields for another geometry. https://www.openfoam.com/documentati...ent-geometries The official tutorial guide explains how to use the mapFileds utility. https://www.openfoam.com/documentati...en-cavity-flow |
Thanks for the reply. I will go through the links you provided. Thanks again! |
