FireFoam Tutorial, HRR overestimated
Like Tree1Likes
  • 1 Post By cunconbkhp
Old   March 24, 2022, 07:12
Default FireFoam Tutorial, HRR overestimated
Huy Quang Dong
cunconbkhp is on a distinguished road
Dear all,
I'm currently learning to use the solver fireFoam. I want to apply this solver for some fire safety projects. I have to evaluate the performance of fireFoam with FDS code.
i'm testing the smallPoolFire3D tutorial. The code runs OK but the Heat release rate is overestimated. I haven't modifies the tutorial, just add function in controlDict to calculte the HRR by volIntegrate of Qdot.
the pool fire area is 0.2 m * 0.2 m = 0.04 m2. The velocity of the methane flux is 0.01 m/s. The density of CH4 is 0.656 kg/m3. The heat of combustion of CH4 is about 50000 kJ/kg. So with the hand calcul, a HRR max of : 0.01*0.2*0.2*0.656*50000 = 13 kW is expected.
However the HRR max caculated with function is 28 kW. The overestimaiton of HRR was notified with older versions of OpenFoam (i've read others topics in the forum). I'm using the OpenFoam 2106. I'm very suprised that this error is still present. In all the tutorials provided, there aren't any measure for HRR???
Please help me if you know any method to repare the problem.
If i'm not wrong, the unit of Qdot is J/m3/s
functions
HRR_vol
type volFieldValue;
//functionObjectLibs ("libfieldFunctionObjects.so");
libs ("libfieldFunctionObjects.so");
log true;
writeControl adjustableRunTime;
writeInterval 2e-2;
writeFields false;
regionType all;
operation volIntegrate;
enabled true;
fields
Qdot
Thanks
Hasnain_1 likes this.
cunconbkhp is offline   Reply With Quote
Old   March 31, 2022, 06:35
Default Problem solved
Huy Quang Dong
Hi all!
I've tested others tutorials and found a solution for my problem :
+ use mass flow rate for the velocity
+ and use the boundary condition of type totalFlowRateAdvectiveDiffusive for the fuel mass fraction.
It's the only combination which give me a good estimation of HRR for the smallPoolFire3D case.
You can study the compartment fire tutorial. My OpenFoam version is 2106.
firefoam, hrr, smallpoolfire3d
[Tutorials] OpenFOAM programming tutorials for beginners Artur OpenFOAM Community Contributions 89 January 13, 2023 19:35
HRR in fireFoam nadezhda OpenFOAM Running, Solving & CFD 8 August 14, 2017 11:09
FireFoam what is HRR ? fgal OpenFOAM Post-Processing 1 April 16, 2010 10:37
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
