The dummy Pstream library cannot be used in parallel mode
Hello everyone,
I tried to run an OpenFoam case with interFoam in parallel and got the following error : "FOAM FATAL ERROR: (openfoam-2012) The dummy Pstream library cannot be used in parallel mode From static bool Foam::UPstream::init(int &, char **&, bool) in file UPstream.C at line 50. " I read some threads on this forum about it but could not find a solution. I also have more information about the MPI: echo $WM_MPLIB: OPENMPI echo $MPI_ARCH_PATH: /xxx/ThirdParty-v2012/platforms/linux64Icc/openmpi-4.0.3 ls -l $MPI_ARCH_PATH: ls: cannot access '/xxx/ThirdParty-v2012/platforms/linux64Icc/openmpi-4.0.3': No such file or directory which mpirun: /opt/intel/2019.4.070/impi/2019.4.243/intel64/bin/mpirun I guess my problem is that i have intelmpi and not openmpi but could not figure out how to solve it Thank you for your help |
By the way, i tried something:
I changed WM_MPLIB and now got: echo $WM_MPLIB: INTELMPI But when i start my simulation again, i got a new error: Sorry! You were supposed to get help about: mpi_init:startup:internal-failure But I couldn't open the help file: /xxx/ThirdParty-v2012/platforms/linux64Icc/openmpi-4.0.3/share/openmpi/help-mpi-runtime.txt: No such file or directory. Sorry! -------------------------------------------------------------------------- *** An error occurred in MPI_Init_thread *** on a NULL communicator *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) [gacn0098:32568] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed! Hope this helps you understand my issue |
