April 12, 2022, 21:43 |
Bug in multiphaseEuleurFoam RAS bubblePipe
Batata Nouhad
When I try to run the case of bubblePipe in RAS it’s can be run I have this :
nouhadaubuntu01:~/OpenFOAM/nouhad-9/run/bubblepipes./Allrun Running blockMesh on /home/nouhad/OpenFOAM/nouhad-9/run/bubblePipe Running topoSet on /home/nouhad/OpenFOAM/nouhad-9/run/bubblepipe Running decomposePar on /home/nouhad/OpenFOAM/nouhad-9/run/bubblePipe Running multiphaseEulerFoam in parallel on /home/nouhad/OpenFOAM/nouhad-9/run/bubblePipe ustng 4 processes Running reconstructPar on /home/nouhad/OpenFOAM/nouhad-9/run/bubblePipe ls: cannot access ../postProcessing/graph//line_alpha*.xy':Nosuchfileordtrectory ls: cannot access *../postProcessing/graph//line_lift*.xy:Nosuchftleordirectory Line ©: warntng: Cannot find or open ftle line ©: warning: Cannot find or open file Line O: warning: Cannot find or open file line O: No data in plot line ©: warning: Cannot ftnd or open file line 0: warning: Cannot find or open ftle line 0: warning: Cannot find or open ftle line O: No data in plot ls: cannot access ../postProcessing/probabtlttyDenstty.tnjection//*.dat':Nosuchftleordirectory ls: cannot access ../postProcessing/probabilityDensity.outlet//*.dat':Nosuchftleordirectory line O: warning: Cannot find or open ftle line O: warntng: Cannot find or open ftle line O: No data in plot CAN YOU PLEASE HELP HOW CAN I FIXE IT I REALLY NEED IT AND I’m still new in openfoam ! |
April 27, 2022, 07:34 |
Muhammad Ahyar
Rep Power: 6 |
you can try to run the command one by one from the Allrun file, try to run these command
> foamCleanTutorials > blockMesh > topoSet > multiphaseEulerFoam here i exclude the decomposePar and reconstrucPar command, just in case the dict file configuration doesn't match your machine's specification. it should run well i thiink. |
mapFields major bug | alchem | OpenFOAM Bugs | 14 | September 15, 2023 12:48 |
Error running RAS kEpsilon | quarkz | OpenFOAM Running, Solving & CFD | 1 | December 31, 2018 03:10 |
Bug in Workbench CFX | Pierre1 | CFX | 6 | August 2, 2017 00:18 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
