FOAM FATAL ERROR: mesh flux field does not exist, is the mesh actually moving? |
June 29, 2022, 13:42 |
Rep Power: 3 |
FOAM FATAL ERROR:
mesh flux field does not exist, is the mesh actually moving? From function const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> &Foam::fvMesh:: phi() const in file fvMesh/fvMeshGeometry.C at line 429. I am trying to refine mesh based on alpha.ndodecane (fuel in diesel engine) by using dynamicRefinefvMesh class and the solver used is 'interPhaseChangeDyMFoam'. But I am gettting above mentioned error every time, I run the simulation. I am also posting the 'dynamicMeshDict' file that I have written for this simulation. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicRefineFvMesh; // Refinement dynamicRefineFvMeshCoeffs { // Refine every refineInterval timesteps refineInterval 5; // Maximum refinement level (starts from 0) maxRefinement 4; unrefineLevel 10; nBufferLayers 1; // Maximum cell limit (approximate) maxCells 500000000; // volScalarField to base refinement on field alpha.ndodecane; // Which cells to un/refine: based on point values (simple averaging). // - refine pointCells of point value inbetween minLevel..maxLevel // - unrefine pointCells that are within nBufferLayers of points marked // for refinement. //minLevel 0.0; //maxLevel 0.8762; lowerRefineLevel 0.001; upperRefineLevel 0.999; // Fluxes to adapt. For newly created faces or split flux // gets estimated from an interpolated volVectorField ('velocity') // First is name of the flux to adapt, second is velocity that will // be interpolated and inner-producted with the face area vector. correctFluxes ( (phi U) (nHatf none) (rhoPhi none) (ghf none) ); // Write the refinement level as a volScalarField dumpLevel true; } // ************************************************** *********************** // Can anyone help me know the reason of this error and if the inputs in 'dynamicMeshDict' are correct or not. Last edited by AbhishekTAMU; June 29, 2022 at 17:18. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
