Compressible turbulent flow in a C-D Nozzle
Hi guys, I am pretty new in OpenFOAM. I am quite comfortable in compressible laminar flows simulations but I am facing problems in compressible turbulent flow simulations. from last five days, I am trying to simulate flow in a CD nozzle. I am using rhoSimpleFoam solver and using komegaSST model, but I am not getting success. I am getting floating point exception error every time.
please help. Much appreciated. I have uploaded all files here: https://drive.google.com/drive/folde...lF?usp=sharing, please have a look. boundary conditions:- FoamFile { format ascii; class volScalarField; object alphat; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -1 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type calculated; value uniform 0; } frontback { type empty; } nozzleWall { type compressible::alphatWallFunction; Prt 0.71; value uniform 0; } outlet { type calculated; value uniform 0; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 6.464664; boundaryField { Inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.03; value uniform 6.464664; } frontback { type empty; } nozzleWall { type kqRWallFunction; value uniform 6.464664; } outlet { type zeroGradient; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class volScalarField; object mut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type calculated; value uniform 0; } frontback { type empty; } nozzleWall { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } outlet { type calculated; value uniform 0; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class volScalarField; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 1031.887318; boundaryField { Inlet { type turbulentMixingLengthFrequencyInlet; mixingLength 0.002464; value uniform 1031.887318; } frontback { type empty; } nozzleWall { type omegaWallFunction; value uniform 1031.887318; } outlet { type zeroGradient; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1.3e5; boundaryField { Inlet { type fixedValue; value uniform 1.3e5; } frontback { type empty; } nozzleWall { type zeroGradient; } outlet { type zeroGradient; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 298; boundaryField { Inlet { type fixedValue; value uniform 298; } frontback { type empty; } nozzleWall { type zeroGradient; } outlet { type zeroGradient; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (69.2 0 0); boundaryField { Inlet { type fixedValue; value uniform (69.2 0 0) } frontback { type empty; } nozzleWall { type noSlip; } outlet { type zeroGradient; } symmetry { type symmetryPlane; } } FoamFile { format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture // air at room temperature (293 K) { specie { molWeight 28.96; } thermodynamics { Cp 1005; Hf 0; } transport { mu 1.82e-05; Pr 0.71; } } FoamFile { format ascii; class dictionary; object momentumTransport; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType RAS; RAS { model kOmegaSST; turbulence on; printCoeffs on; } FoamFile { format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application rhoSimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 2000; deltaT 1; writeControl adjustableRunTime; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; graphFormat raw; runTimeModifiable true; FoamFile { format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; limited cellLimited Gauss linear 1; grad(U) $limited; grad(k) $limited; grad(omega) $limited; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind limited; turbulence bounded Gauss upwind; energy bounded Gauss linearUpwind limited; div(phi,k) $turbulence; div(phi,omega) $turbulence; div(phi,e) $energy; div(phi,K) $energy; div(phi,Ekp) $energy; div(phid,p) Gauss upwind; div((phi|interpolate(rho)),p) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } FoamFile { format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; } "(U|k|omega|e)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-10; relTol 0.1; } } SIMPLE { residualControl { p 1e-6; U 1e-5; "(k|omega|e)" 1e-5; } nNonOrthogonalCorrectors 0; } relaxationFactors { fields { p 0.3; rho 0.01; } equations { U 0.7; e 0.7; "(k|omega)" 0.7; } } |
